The kit is available either for electric or slime power. Check out rsmdistribution.com for the catalog. .15 modern or an old .19 engine would be appropriate.
BTW I put in a first flight today. Hoooeee! What a trip. Too much elevator throw, too short lines (46'), tail heavy and me being tired from helping to clean up the field for next week's contest. But it got down with only scraped prop tips. Wow amount of power.
I will continue to update this thread as I tame the beast. I moved the battery 1/2" forward, will cut the handle line spacing down, and then will consider adding some noseweight.
I am going to go to 55' lines as I have more than enough power to handle them. I also have a 50' set already if the long ones are too much.
Being a 1/2A enthusiast, I can handle quick airplanes, but this one was beyond my skill! Thank goodness for my RC throttle handle! Even so, landing was a disaster.....all four times. I would get a little bounce, a big bounce then hit the throttle to go around for another try. That, at least worked great!
I did do a loop and wingover, but both very sloppy.
And I have to have it tuned in for 1 week from today! Wish me luck (and the intelligence to figure it all out).
