  • May 10, 2024, 05:05:51 PM
Author Topic: Rib Spacing  (Read 5535 times)
Online Motorman
Rib Spacing
« on: May 27, 2015, 12:23:48 PM »
I see some planes with more ribs than others. Is this a trade off between better stiffness and airfoil shape vs weight? Is anything less than 3-1/2" spacing really necessary on a 600 sq. in. wing?
MM
Re: Rib Spacing
« Reply #1 on: May 28, 2015, 10:29:30 AM »
   3 and a half inches?  I don't know about that, most are more like 2" and I have considered adding half-ribs every inch to avoid "starved horse" problems.
Offline Chris Wilson
Re: Rib Spacing
« Reply #2 on: June 30, 2015, 08:17:13 PM »
  .............. I have considered adding half-ribs every inch to avoid "starved horse" problems.
Which brings up the next question "why avoid the starved horsy thing?" (Or as we say here in Oz "built like a roasted greyhound.")
Purely appearance?
MAAA AUS 73427
Re: Rib Spacing
« Reply #3 on: July 01, 2015, 12:31:49 PM »
The sagged part is less than the intended airfoil thickness.  If you scientifically selected the airfoil, don't you want it everywhere?
Online Tim Wescott
Re: Rib Spacing
« Reply #4 on: July 01, 2015, 01:10:13 PM »
3.5 inches isn't too bad behind the spar, although if you want more I'm not going to prevent you.  If I'm building something without sheeting ahead of the spar I like to put in half-ribs (my latest RC plane is an Ugly Stick with two half ribs for every full rib, with about 3" spacing between full ribs but 1" spacing between half ribs).
Re: Rib Spacing
« Reply #5 on: July 01, 2015, 04:07:55 PM »
Hi Paul,
            I thought that may be the obvious answer but I have yet to see a model suffer from the lack of scientific airfoil in the bays.
Perhaps the "starved horse" ribbing helps to prevent span wise flow? Or an average between the minimum and maximum sections allows better for varying conditions?
Thanks.
MAAA AUS 73427
Online Tim Wescott
Re: Rib Spacing
« Reply #6 on: July 01, 2015, 05:07:11 PM »
Some of the Seilig(sp?) airfoils are designed with covering sag in mind; the published airfoil data is actually more a rib profile rather than what you expect the wing itself to be.
Re: Rib Spacing
« Reply #7 on: July 01, 2015, 07:47:27 PM »
   I would not claim that my airfoil was carefully selected based on science! However, I want the things that are supposed to be straight to be straight, the curved parts curved and no "accidental" shapes. My turtledeck is a bit "starved horse" and I have often wanted to cut it off and make a new, correct replacement. So far I have resisted.
Re: Rib Spacing
« Reply #8 on: July 01, 2015, 07:49:13 PM »
Brett,
replacing the turtledeck would be faster than building a new plane!
heck you have a week before the nats,, get to it LOL
Re: Rib Spacing
« Reply #9 on: July 02, 2015, 09:07:48 PM »
There are plenty of real airplanes and lake freighters with the covering shrink over the ribs on the body (or hull).  But airplane wings are generally built to keep the airfoil true.  Stunters and combat planes have so much excess lift, you wouldn't know or care if it's efficient or not.  The only way to tell would be to build another plane with the wing sheeted to keep the airfoil true.
Re: Rib Spacing
« Reply #10 on: July 02, 2015, 09:22:52 PM »
Brett,
   I would be better off finishing the almost-finished clone (that has been sitting in that state for about a year...).
Offline phil c
Re: Rib Spacing
« Reply #11 on: July 03, 2015, 05:13:32 PM »
You can select an airfoil scientifically.  But as Mike Selig at UIUC proved, building a wing with close enough tolerances to get realistic performance measurements is VERY difficult.  And when you do the differences are only apparent at the very extremes of performance.
phil Cartier
