Hi Dennis. When I opened up the cowl and tank cover to check the plumbing, I looked for a leaky pressure line as well as the other lines, but all seemed okay. I'll give it another once over in the shop before I hit the field again Tuesday. Might as well replace all of the lines and pressure check the tank too. But it was perfectly on song after I closed it back up at the field and filled it with Powermaster. When I cranked it with the Sig, I had to richen the mixture to get it down to my launch RPMs, about 11.5k. Still a little leaner than my next powermaster launch, a nice run at 11.1k. I prefer to use my ear, but since I'm still getting used to this setup I decided to tach it.
Since it sagged during the rollout is the reason I first suspected weed seeds. If you could see the short seedy little sprouts at the field, you'd understand what I'm referring to. I have my pitman hold it off the ground until I have my lanyard strapped on and am ready to fly. The Oriental's LG is pretty short too, no doubt mowing the grass as it rolls. I hope it's that simple.
