  • April 19, 2024, 05:11:36 AM
Author Topic: Tower Website - Where Are the OS LA-S engines?  (Read 4746 times)
Offline Steve Scott
« on: April 12, 2015, 06:09:17 PM »
I just tried to look up an OS .25 LA-S on Tower's website and it appears they no longer carry any of the OS LA-S CL engines.  Not listed under category or by brand.  If fact, the only non-RC glow engines are the ST .34 and .51 sizes.
Bummer...
Offline Geoff Goodworth
Re: Tower Website - Where Are the OS LA-S engines?
« Reply #1 on: April 12, 2015, 06:21:49 PM »
Steve, this subject was done to death under teh topic OS engines further down the page.
Offline dennis lipsett
« Reply #2 on: April 12, 2015, 06:42:07 PM »
Rusty,
it is never called the empire rather it is the 'Evil Empire' or my favorite, Great Pain.
Dennis
Offline Steve Scott
« Reply #3 on: April 12, 2015, 06:58:23 PM »
Apologies, I did a search for 'Tower' before I posted.  Didn't get a hit on the earlier thread.
Offline Steven Kientz
« Reply #4 on: April 13, 2015, 02:39:55 PM »
I received a new Tower Talk ad in the mail today. Page 28 shows the OS 25 LA-S for $79.98. The .46 is listed under La for R/C. I guess their marketing dept. isn't in the loop.
Steve Kientz
AMA 855912
Online RC Storick
« Reply #5 on: April 13, 2015, 04:16:13 PM »
Bummer...
http://www.towerhobbies.com/products/os_engines/air_la_engines_index.html
« Reply #6 on: April 13, 2015, 04:30:45 PM »
Yes,
Late April. No reason the quality should be any different in this next batch?
« Reply #7 on: April 15, 2015, 09:18:23 AM »
OS LA .46 R/C to OS LA .46 CL.
Venturi, NVA, metal backplate.
NDAIAA. Nothing difficult about it at all.
Offline Chris Belcher
« Reply #9 on: April 15, 2015, 03:14:15 PM »
One does have to drill out the case for the st needle..it's .156, bigger than the OS. I think OS is .130. And replace the phillips with socket heads...well you don't HAVE to but...
« Reply #10 on: April 15, 2015, 04:33:26 PM »
 That's true for an ST needle or the various clones/  I would suggest getting the stock OS spraybar assy =- I think it goes right through the existing hole.
« Reply #11 on: April 24, 2015, 05:15:14 AM »
I just got an E-mail from Tower Hobbies.
Says they now have OS LA .46 R/C engines in stock.
« Reply #12 on: April 24, 2015, 08:34:19 PM »
Brett's correct. The screws holding the carb are M3.5 so the stock OS NVA slips straight in.
« Reply #13 on: April 24, 2015, 09:32:03 PM »
That's true enough, but then you're stuck with an OS NV Assy and nothing else (pretty much) will fit. At least, nothing that is commonly available in your buddy's field kit. Besides, does the ratchet system work as well as Randy Smith's plastic collet setup? No, sorry, not even close.   S?P  Steve
« Reply #14 on: April 24, 2015, 10:48:44 PM »
The OS needles work fine in the LA engines. Many of those flying around that way.
Offline Dick Pacini
« Reply #15 on: April 25, 2015, 12:53:23 AM »
Which OS needle assembly?
AMA 62221
Offline Wayne J. Buran
« Reply #16 on: April 25, 2015, 05:23:40 AM »
OS 22311000 20-40FP-s Needle valve assembly if you can find them.
Wayne
Wayne Buran
Medina, Ohio
AMA 14986 CD
« Reply #17 on: April 25, 2015, 06:20:29 AM »
With profile mounted engines, there's no hole to make in the fuselage. I have a few NVA that are "ratchet" and I'm not using them because of a larger hole needed in the fuselage. I only have one "ratchet" type on my profile Pathfinder.
Steve is making plenty of sense.
I have a plastic collet type NVA and I cannot remember where I got it?
I'd like to see a photo of Randy's offering. I'm convinced it would be my choice.
Photo anyone?
« Reply #18 on: April 25, 2015, 10:01:43 AM »
Ugh. Please. I choose to believe my lying eyes (and ears). Tower has the OS needles back in stock. I just ordered 3. Listed as   FP 20-25 needle for some reason. Same needle.
« Last Edit: April 25, 2015, 02:06:48 PM by Dennis Moritz »
Offline John Rist
« Reply #19 on: April 25, 2015, 12:50:59 PM »
Wayne
In stock at Tower
http://www3.towerhobbies.com/cgi-bin/wti0095p?FVSEARCH=+22311000
John Rist
AMA 56277
Offline Leester
« Reply #20 on: April 25, 2015, 01:22:43 PM »
Charles... Here is a Randy Smith Aero Products PA NVA
Leester
ama 830538
« Reply #21 on: April 25, 2015, 02:15:57 PM »
The Randy needle has a finer thread, finer adjustment. Useful in some applications. The click click OS needle works well in the LA46. An engine with a wide spread of usable tune. Using it means no need to drill the case. Not so easy to get the holes true and exactly lined up. Holes which then have to match venturi holes. Folks asking these questions benefit from the easy fit of an OS stock needle. They are not the most experienced. The comparatively docile LA46 does fine using the stock FP clicker. Any contest I've attended, since these engines were discovered, is flooded with LA46s using OS needles.
Offline John Rist
« Reply #22 on: April 25, 2015, 03:32:58 PM »
Where can I get a metal back plate for the LA 46
John Rist
AMA 56277
« Reply #23 on: April 25, 2015, 04:42:46 PM »
Leester,
Thanks for posting that photo. I actually have one of them. Possibly purchased from Randy or from another CL modeler.
I will send Randy a note and purchase a couple of them.
Great for any application, especially scale or semi-scale, with that long thin needle.
Thanks again.
Offline Steve Scott
Offline Steve Scott
« Reply #25 on: April 27, 2015, 06:50:29 PM »
Go to their website and pound in the code TE1422 for the 25LA-S and it comes up Discontinued.  Same for the TE1420 25LA RC engine.  TE1421 for the 46LA RC engine shows they are still in stock.
« Reply #26 on: April 27, 2015, 10:09:14 PM »
    I think it's a toss-up. I actually prefer the click-type needles in principle, and the OS type supports the needle much better than the ST. The needle is a close fit in the (smooth) bore so the needle is supported all the way to where the taper starts, as opposed to on the very tip end of the collet. The support at a single point sometimes makes the needle vibrate like a tuning fork. I have it on an unimpeachable (almost literally, it seems...) source that Big Jim first diagnosed the issue.
   It's easy to be too clever with the adjustments with no clicks.
   The big improvement that the Randy and Jett spraybars have over the ST is that the teflon or nylon packing washer damps the tuning fork vibration you get with the ST.
« Reply #27 on: April 29, 2015, 04:10:50 PM »
I just purchased a NVA from Randy Smith.
I have a poor memory, but I believe I may have purchased one from Randy a while back?I'll know when I get it.
It's not of the ratchet type. I need one like Randy's for The Tank Buster. Allows for a much smaller exit hole.
Click on the Aero Products photo and the airplane will fly.  ;D
« Reply #28 on: April 29, 2015, 05:13:46 PM »
Considering that I have had them on order for months and a Kaz handle and still waiting you must be 'special'
« Reply #29 on: April 29, 2015, 05:35:18 PM »
Dennis,
I'm being put on the list also.
My model is far from finished, The Tank Buster, so I'm not in any hurry.
Offline Bill Morell
« Reply #30 on: April 29, 2015, 07:35:50 PM »
I clicked on the Aero Products photo and your airplane didn't do a thing.........
Bill Morell
Vietnam 72-73
Offline billbyles
« Reply #31 on: April 30, 2015, 12:23:19 AM »
You mean it still hasn't flown...?
Bill Byles
AMA 20913
So. Cal.
« Reply #32 on: April 30, 2015, 08:49:48 AM »
Dennis,
What is a Kaz handle?
Offline Peter Grabenstein
« Reply #33 on: April 30, 2015, 10:07:32 AM »
Dennis,
Custom made handle (only for CL Stunt use) I guess, design by
World Top Class F2B Pilot Mr. Kaz (firstname) Minato (lastname) Japan.
Tight Lines  H^^ Peter
BTW drifting "off-Topic"
I hate pessimists, I prefer optimists.
Impossible is done immediately, miracles take longer.
I don't care who your father is ......... as long as I fly here,
Nobody walks, runs, floats or flies across my circle ......... not even to fetch fish, wine or bread.
« Reply #34 on: April 30, 2015, 10:37:59 AM »
Peter,
I'm drifting! Read back a few posts.  LL~
Should there be a Thread on that handle? Photo.
Steve Scott is the PO
