  • April 24, 2024, 12:47:53 AM
Author Topic: Multi Charger  (Read 10156 times)
Offline eric rule
Multi Charger
« on: April 07, 2015, 09:49:51 PM »
If you fly electric you have found like I have that it is a pain charging all those batteries one by one. RSM is pleased top announce that we have obtained a number of Multi Chargers. Now you can charge 4 batteries at once using one charger. The genuine Imax Multi Charger is now in stock at RSM Distribution. This charger runs on AC at home and on DC at the flying field. This excellent charger is priced at only $189.99 which is much lower than comparable chargers on the market. We can do this because we purchase directly from the factory. Supplies are limited so call 951-678-1406 or e mail eric@rsmdistribution.com now to get yours.
Offline eric rule
Re: Multi Charger
« Reply #1 on: April 07, 2015, 10:04:14 PM »
QUATTRO B6AC is a high-performance, micro processor control charge/discharge station with battery management suitable for use with all current battery types. With integral equalizer for six-cell Lithium-Ion (LiIon), Lithium-Polymer (LiPo) and Lithium-Ferrum (LiFe) batteries.
Maximum 6A charge current; can be powered by a 12 Volt car battery or from the 110V AC(US Version) or 220V AC via the built in switch-mode power supply.
And the circuit features four totally independent identical power outputs which are powered 50 watts each. Total powers are 200 watts. As a result , it can charge or discharge up to 4 x 15 cells of NiCd/NiMH or 4 x 6 series of Lithium batteries simultaneously. Quattro B6AC has four individual cell voltage balancer at each outputs, so it does not required any balancer separately when charging Lithium Battery (LiPo/LiIon/LiFe) for voltage balancing.
When a Nickel battery is fully charged, the unit terminates the process using the Delta-Peak method. Lithium and lead (Pb) batteries are charged using the CC-CV method.
QUATTRO B6AC allows you to plug 4 batteries into one charger simultaneously, and it will intelligently and automatically charge all 4 of them at once to their maximum capacity. On top of this, the batteries being charged do not even need to have the same configuration. You can connect different chemistry(Ni-MH/Ni-CD/LiPo/LiFe)batteries into any of the charging ports. No more staying up late for charging batteries.
Optimized operating software
QUATTRO B6AC features the so-called AUTO function that set the feeding current during the process of charging or discharging. Especially for Lithium batteries, it can prevent the overcharging which may lead to an explosion due to the user's fault. It can disconnect the circuit automatically and alarm once detecting any malfunction. All the
programs of this product were controlled through two way linkage and communication, to achieve the maximum safety and minimize the trouble. All the settings can be configured by users!
Internal independent lithium battery balancer
QUATTRO B6AC employs an individual-cell-voltage balancer. It isn't necessary to connect an external balancer for balance charging.
Balancing individual cells battery discharging
During the process of discharging, QUATTRO B6AC can monitor and balance each cell of the battery individually. Error message will be indicated and the process will be ended automatically if the voltage of any single one cell is abnormal.
Adaptable to various type of lithium battery
QUATTRO B6AC is adaptable to various types of Lithium batteries, such as Li-ion, LiPo and the new LiFe series of batteries.
Fast and storage mode of lithium battery
Purposes to charge Lithium battery varies, 'fast' charge reduce the duration of charging, whereas 'store' state can control the final voltage of your battery, so as to store for a long time and protect useful time of the battery.
Maximum safety
Delta-peak sensitivity: The automatic charge termination program based on the principle of the Delta-peak voltage detection. When the battery's voltage exceeds the threshold, the process will be terminated automatically.
Automatic charging current limit
You can set up the upper limit of the charging current when charging your NiCd or NiMH battery, it is useful for the NiMH battery of low impedance and capacity in the 'AUTO' charging mode.
Capacity limit
The charging capacity is always calculated as the charging current multiplied by time. If the charging capacity exceeds the limit, the process will be terminated automatically when you set the maximum value.
Quatro Charger Specs
AC Input (US Version): 100-120V(380-330W)
                (EU/UK/AU/CHN Version): 220-240V(380-330W)
DC Input: 11-18Volt
Charger circuit power: 4 x 50W(200W)
Charge current range: 0.1-6.0A
Discharge current range: 0.1-1.0A
Current drain for balancing port: 300mA/cell
NiCd/NiMH battery cell count: 1-15Cells
LiPo/LiFe/Lilon cell count: 1-6Cells
Pb battery voltage: 2-20V
Net weight: 1.57kg
Dimension: 225x170x66mm
