I finally got a good SS40 BB! The first one I got ended up with a crack in the case. I don't think the seller knew it but when I disassembled the engine, there was also some mud in part of the carb. He refunded my money with no problem.
So I got another one. This appears to be a low-time engine. Knowing Enya's take a lot of break-in, I kind of followed your advice, Martin, and did the 10 minute run on Powermaster GMA 10/29 fuel. That's all-castor. Let it cool completely and did a couple runs on 2oz of fuel, leaning it by pinching the line. Then I lost my mind, ran it a full 14oz, about a 30 minute run, just barely 4 stroking and tilting the test stand back to about a 60 degree angle and the engine transitioned smoothly to a wet 2 stroke. This is one an APC 11-4 prop. Another full 30 minute run transitioning 4 stroke to 2 every 5 minutes.
The engine's a beast! This is subjective, of course, but it sounds as if it's running at least 1K RPM faster than the OS 46LA. And it flip starts on one flip after priming.
