  • April 18, 2024, 07:16:22 PM
Author Topic: Painting a Metal Tank  (Read 1730 times)
Offline mike londke
« on: March 27, 2015, 07:54:28 PM »
Has anyone ever painted a metal tank on a profile model? If so what did you use. What was the prep?  Anyone tried rattle can Lusterkote? Thx, Mike
AMA 48913  USPA D-19580  NRA Life Member  MI State Record Holder 50 way Freefall Formation Skydive  "Don't let the planet sneak up on you"
Offline Mike Keville
Re: Painting a Metal Tank
« Reply #1 on: March 27, 2015, 09:07:46 PM »
Clean the tank well with isopropol alcohol to remove all oil/grease.  Let it dry.  Plug all openings, then spray with Ace-brand metal primer.  Let dry, then top coat with Krylon "Fusion" (fuel-resistant) color.
Offline mike londke
« Reply #2 on: March 27, 2015, 10:44:59 PM »
Thanks, I will give it a try. I may test the Ace primer with a top coat of Lusterkote on a spare tanks just to see the results.
« Last Edit: March 28, 2015, 07:49:23 AM by mike londke »
« Reply #3 on: March 27, 2015, 10:59:54 PM »
Rustoleum works well, too.  Clean the bejezus out of it, spray with metal primer, spray with Gloss Protective Enamel.
Offline Joseph Patterson
  • AMA member- Supporter
« Reply #4 on: April 16, 2015, 02:51:45 PM »
   Mike, you are the first person I've heard mention Krylon "Fusion" being fuel proof. I'm going to check it out. What type paint is it now? They sure have a bunch of neat colors to choose.
           Doug
« Reply #5 on: April 16, 2015, 03:31:19 PM »
Getting the tank really clean is very important!  Then using a good metal primer you can use just about any top coat you want to as long as it is fuel proof.  Or you can even shoot the color then apply a coat of "Death Paint". :)
BIG Bear
RNMM/AMM
Offline Target
  • C/L Addict
« Reply #6 on: April 16, 2015, 03:41:02 PM »
Death paint??
Depth paint, meaning clear?
Chris
Chris
AMA 5956
« Reply #7 on: April 16, 2015, 04:07:15 PM »
Death paint??
It's a nickname for paints with really toxic ingredients, like 2-part urethanes with isocyanate activators.
If the MSDS calls out encasing yourself in rubber and wearing a positive-pressure mask -- it's death paint.
Offline mike londke
« Reply #8 on: April 16, 2015, 05:30:52 PM »
I took an old tank and I did some tests with Ace metal primer and used Top Flite Lusterkote black then clear. It went on well and had no reactions so I went ahead and shot the new tank the same way. It looks good. We'll have to see how it holds up.
Offline Target
  • C/L Addict
« Reply #9 on: April 16, 2015, 08:19:48 PM »
Hahaha, Death Paint, eh?!
We used to use a bottom paint on aluminum hulled boats called, "Tin Tox", no there was some "Death Paint"! It worked real good, not allowed anymore, it worked too good I guess!
I might have to paint the tank on my Banshee....Not tonight though, tomorrows the maiden!
I hope to get a durability report on the painted tank soon, Mike.
Hope its a happy/good one!
Kind Regards
Chris
AMA 5956
