Hi Frank -
There's a bit of a back-story involved.
I'd posted previously about the low power output of this engine and had gotten advice from Jim and others about that, with no improvement.
Then I ran across the glow plug issue initially addressed here and that was quite perplexing, as the T-Bolt is perhaps the most highly recommended hot plug.
Jim's comments above have now led to a resolution of the power problem, and seemingly the plug issue also.
I just got through trying all 3 plugs again, and in fact, I still have a couple hundred rpm drop on the OS and McCoy plugs with the igniter removed, while the T-Bolt now shows no discernible drop.
200 rpm isn't a really big deal, as the engine varies more than that on 4-cycle, which at this point I'm chalking up to a need for more re-break-in.
With all 3 plugs it now turns a 10-6 APC to 10.7ish K, pinch-leaning.
I don't know how or if any of it relates to your difficulties but I do hope you find something as successful for you as this has been for me.
I'll read your posts and at least commiserate with you.
regards,
Terry
P.S. - I'm still not a fan of the ST nva. I prefer a FOX!!!!
