  • April 19, 2024, 12:54:31 AM
Author Topic: Evolution 36 CL  (Read 2668 times)
Offline David Ruff
Evolution 36 CL
« on: March 13, 2015, 02:54:09 AM »
I have two new Evo 36 CL engines with the remote NVA.
What do I need to convert to standard front NVA on the venturi?
Retired Army
Re: Evolution 36 CL
« Reply #1 on: March 13, 2015, 03:02:29 PM »
I have OS NVAs  that will thread into one side and make them front Needle, that works well, also Jim Lee makes adapters that hold a ST or PA NVA in the front hold down hole either works
Offline David Ruff
Re: Evolution 36 CL
« Reply #2 on: March 14, 2015, 04:19:18 PM »
Randy..which OS NVA do I need.  I will order..
Retired Army
Re: Evolution 36 CL
« Reply #3 on: March 14, 2015, 09:11:38 PM »
They are the 2a OR 3a RC needle assemblies, they just screw into the small EVO venturie
Offline David Ruff
Re: Evolution 36 CL
« Reply #4 on: March 20, 2015, 04:21:52 PM »
Randy..received the NVAs today.  Thanks.  Will let you know how it works.
Retired Army
Re: Evolution 36 CL
« Reply #5 on: March 20, 2015, 04:31:34 PM »
FWIW: If you haven't found out yet, Evo 36 (and 60s) don't like castor oil. Run it on regular R/C fuel or even full synthetic. For the 36, high rpm, low pitch is the way to go. Lots of power however don't expect a Fox 35 type run. 8)
Tags: NVA
