Here's what I've got so far on building the Winder with electric motor. I added a removable nose gear so that I can launch by myself. There is a hatch for the battery and ESC compartment. The hatch is secured by magnets. The small screw head is a handle for removing the hatch. Plan to add some vents on the underside of the battery/ESC compartment for cooling the battery and ESC. I widened the sheeted area to make it easier to attach Monokote covering. Plan to paint the center section, and Monokote outside of that. Added a length of 1/8 x 1/2 hardwood strip to the back of leading edge in order to increase strength. Need to decide on how much wingtip weight to add.
