Remove the glow plug and rear cover. Heat in the oven at about 180 degrees for about 15 minutes or so. IF it is castor gummed, the heat has started the process of returning the castor to a liquefied state. Once you retrieve the baked engine, using gloves, prop the still hot engine and start to turn it over. It should start to turn. Squirt some fresh fuel into the exhaust and the rear of the engine and continue turning the engine over. It should loosen up nicely. Once it does, then clean out the fuel residue and treat with your favorite after-run oil.
