Hello friends,
I hope you understand the process of painting I did in the prototype.
Come on, I'll try to write as clear as possible.
Fuselage ---... coat the balsa wood with silkspan, applied dope with aluminum powder, not to use the primer. I applied the background color (solid yellow) and in the bee hive painted with metallic yellow.
Wing --- ... was covered with "yellow transparent Oracover". Bee hive was done with the same manner of the fuselage.
After all this painting, a thin layer of "ink blue chameleon" that changes color depending on the position of the light was applied.
After all this, was added in small metallic varnish sparkling particles, which are also color change as the light position.
All this we used an airbrush and masks cut out of a vinyl plotter.
Not ready yet, but in a few days you will see pictures of how it was and its effect on the change of light.
Thank you all, I hope you are understanding what I write!
Bro Cremon!
