Can you fill the bypass on the Fox 35 too much and cure the burp but lose the 4-2-4? I modified the case on a 40th anniversary model with JB Weld, filling it maybe about 2/3. The motor is upright mount and does not burp - ever, never.
However, it also keeps jumping from either a solid 4 cycle that is to slow to a wet 2 cycle which works but not what I want. I've done the fuel switch, plug switch, head gaskets, stuffer backplate, hemi head. It always runs the same. The only thing is the bypass mod. Could I have filled the bypass too much? Could this cause the charge to blow through to fast and mess up the loop flow in the cylinder?
Best, DennisT
