  • April 18, 2024, 10:32:50 PM
Author Topic: New Goodyear Margaret June  (Read 22838 times)
Offline bill bischoff
« on: November 19, 2014, 02:33:59 PM »
This is my new Sport Goodyear, Margaret June. For you air racing fans, this plane was previously "Bullitt" and "Cool Runnings". I just shot primer on it today. To try to stir up interest in this event for the 2015 NATS, I am working on plans and a construction article, hopefully to be published in Model Aviation. If they don't want it, I will make it available myself. I am shooting for having everything done by the end of the year.
Offline big ron
Re: New Goodyear Margaret June
« Reply #1 on: November 19, 2014, 04:48:21 PM »
Bill getting ready to put venturi and needle valve that I got from you in Houston in the magnum 15 any tips for spraybar position or breaking in.
John Blanchard
Brusly, Louisiana
 AMA 1054488
« Reply #2 on: November 19, 2014, 05:37:34 PM »
Point the hole straight down the throat of the venturi. We break in and fly with the same prop, the APC 6.5x5.0. If you can't get one locally, any 7x4 will be OK. You don't need a slobbery rich, slow break in. Run at a rich two cycle then lean it out for 10-15 seconds at a time to heat it up. I'm sure you can find a more detailled procedure somewhere on StuntHangar.
Online George Grossardt
« Reply #3 on: November 19, 2014, 07:08:49 PM »
Awesome.  Hope MA picks up your work. It would be nice to see a C/L racing build for a change.
« Reply #4 on: November 20, 2014, 09:15:53 AM »
Plane looks great.  I need a new Sport Good Year.   I'm still trying to get some engines also.   If MA doesn't pick up on it, I would like a set of plans.  Thanks DOC Holliday
Offline Balsa Butcher
  • High Desert Flier
« Reply #5 on: November 23, 2014, 05:32:28 PM »
I'm with Doc. Not much racing around my neck of the woods but that plane is so pretty I would build one just 'cause I like flying fast, cool airplanes. Put me down for a  set if MA passes (maybe if it was made out of cardboard or styrofoam they might show more interest). ;D HB~> 8)
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #6 on: November 23, 2014, 05:52:12 PM »
Progress is being made.
Offline big ron
« Reply #7 on: November 24, 2014, 12:27:13 PM »
Looks good Bill looking forward to the article is the lil quickie AMA plans a good one for this class?
John Blanchard
Brusly, Louisiana
 AMA 1054488
« Reply #8 on: November 24, 2014, 04:49:54 PM »
The Li'l Quickie is a great airplane. That is what Don Cranfill and Richard Oliver fly. The Plum Crazy Cassutt from Flying Models (mid 1970's) is another good one. It already has external controls, and a shutoff similar to mine. You can't go wrong with either one.
Offline big ron
« Reply #9 on: November 24, 2014, 05:25:19 PM »
Are The plum crazy plans available?
John Blanchard
Brusly, Louisiana
 AMA 1054488
Offline BillLee
« Reply #10 on: November 24, 2014, 07:14:22 PM »
Ron, the plans Bill posted above are the Plumb Crazy Cassutt plans.
Bill Lee
AMA 20018
« Reply #11 on: November 24, 2014, 10:00:48 PM »
go to: carstensbookstore.com, order plan CF 301.
« Reply #12 on: November 26, 2014, 03:52:25 PM »
More progress. I may even try a few ink lines...
Offline bob whitney
  • Moderator
« Reply #13 on: November 26, 2014, 07:47:41 PM »
  too nice to race  you need to be real carefull ,dont land too hard and bring it to the pit man real easy so u dont ding the wing S?P
rad racer
« Reply #14 on: November 26, 2014, 09:33:57 PM »
What are you saying, Bob? You sound as if you know me (and Mike too!)  :-*
Offline bob whitney
  • Moderator
« Reply #15 on: November 26, 2014, 09:48:28 PM »
  probly longer than u realize, u still have my 1st nats F2C trophy LL~
rad racer
« Reply #16 on: November 27, 2014, 09:13:45 AM »
What kind of hinges are those?
« Reply #17 on: November 27, 2014, 12:59:55 PM »
As shown, the hinges aren't hinges. They're music wire "staples" to hold the elevator during painting. They will ultimately be 1/2A dacron flying line sewn hinges.
Do you mean the time Fast Freddy ran out of the circle before the race was over?
Offline Wayne J. Buran
« Reply #18 on: November 27, 2014, 04:18:51 PM »
Looking forward to seeing pictures of it assembled. I would like to see the B/C setup.
Wayne
Wayne Buran
Medina, Ohio
AMA 14986 CD
USAF Veteran 35 TAC GP/ 6236 CSG, DonMuang RTAFB, Bangkok, Thailand 65-66 North Coast Controliners   "A fine is a tax for doing wrong. A tax is a fine for doing well!
« Reply #19 on: November 27, 2014, 05:32:33 PM »
Wayne
This is a different airplane, but the control system is the same. I am using the same hex shaped buttons to connect the lines to the bellcrank as I use on my carrier planes. It has been previously described in the carrier section.
Offline bob whitney
  • Moderator
« Reply #20 on: November 27, 2014, 07:32:36 PM »
 thats the one ,if it had been anyone but fred, Garner probly wouldnt have said anything but such is life  n~
rad racer
« Reply #21 on: November 28, 2014, 08:47:14 AM »
Bill, thanks for the picture. Nice install. You do great work.
Wayne
Wayne Buran
Medina, Ohio
AMA 14986 CD
« Reply #22 on: November 28, 2014, 10:51:13 AM »
Well I didn't want to mention names as I think he was upset also that he had a brain f--t.
« Reply #23 on: November 28, 2014, 08:40:06 PM »
Is that considered an exposed bellcrank if the rules say it must be exposed. Thinking of doing something like that on a proto but didn't want to risk a DQ.
MM
Offline bob whitney
  • Moderator
« Reply #24 on: November 28, 2014, 10:24:54 PM »
  there is a diff between exposed and extrenal
rad racer
Offline BillLee
« Reply #25 on: November 29, 2014, 07:04:07 AM »
MM
Walt, the rules for Sport GY are quite explicit regarding the control system. I don't know what the proto rules say, and I certainly would not base a proto model on the Sport GY rules.
From the DMAA website:
MODEL SPECIFICATIONS FOR MAGNUM/ ASP ENGINES ONLY: Lines may attach directly
to the bellcrank, or leadouts may be used. The bellcrank and leadouts or lines must be external to the
normal contours of the wing. The line/ leadout guide(s) may be inset into the wing, but shall cover no
more than 1/2" of the lines or leadouts. The bellcrank may pass through the fuselage but must be visible
and not fully enclosed. The pushrod and elevator control horn shall not be recessed or enclosed in the
fuselage. Fuel shutoff linkages are exempt from any of the above regulations.
Bill Lee
AMA 20018
« Reply #26 on: December 06, 2014, 03:02:18 PM »
The airplane is done, the article is done, now I just have to finish the plans. Weight is 21 oz, preliminary balance looks good. First flights are tomorrow.
« Reply #27 on: December 07, 2014, 08:04:41 AM »
Hope it is as fast as it looks.
Jim Roselle
« Reply #28 on: December 07, 2014, 03:10:47 PM »
Man, that's a beauty! Makes me want to build a Goodyear even though I don't have anyone to race against.
Jim
« Reply #29 on: December 07, 2014, 07:12:35 PM »
Build one! Lead the charge. Stir up some interest. Better yet, build two, hand someone else the handle, and there you go, instant race! If you really want to get 'em hooked, let the other guy fly the faster plane!
Offline James McKinney
    • MACA Website
« Reply #30 on: December 07, 2014, 07:24:48 PM »
hmmmm... I want to race! Haven't flown a race sine i was like 16.. sport goodyear eh?
« Reply #31 on: December 07, 2014, 08:39:13 PM »
Come to one of our contests. We always need pilots. Of course if you want to build one of your own, so much the better. Talk to Allen DeVeuve. He was going to team up with Lester to fly some racing, then Lester got busy with a new job and a new baby. Allen wants to do the pitting, so if you want to fly you can probably get something going.
  • High Desert Flier
« Reply #32 on: December 16, 2014, 07:13:08 PM »
Say Bill, any chance for details on the fuel shut-off? The ones I use incorporate a separate on a "U" shaped aluminum bracket and the cable activited trigger is on the top. This set-up looks cleaner, lighter, and just as reliable. Can't make Dallas to race but there are still a few guys in the SF Bay area doing it. 8)
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #33 on: December 16, 2014, 09:38:58 PM »
It's super simple, and made from easily obtained materials. The drawing is lifted straight off the Margaret June plans. Don't be confused, though. The last picture is a different airplane.
  • High Desert Flier
« Reply #34 on: December 16, 2014, 10:41:17 PM »
Thanks Bill, that's brilliant! I will retro-fit one to my Super-Fly Fox racer.  8)
« Last Edit: December 17, 2014, 09:56:40 PM by Balsa Butcher »
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #35 on: December 17, 2014, 11:51:09 AM »
Ah, back to basics.   I still remember the crude ones we tried before Kevin Seaton came up with his.
Offline Dave Rolley
« Reply #36 on: December 25, 2014, 08:09:41 AM »
Pictures from the full size Margaret June's first flight at the Kissimmee FL airport:
2014 Margaret June Silver Final race @ Reno NV, cockpit camera looking aft.  It is about 30 minutes long, includes pre-race countdown.  Notice how low they are flying!:
« Reply #37 on: December 25, 2014, 09:14:43 PM »
Thanks for one terrific ride.   The pilot looks so relaxed.
Offline Tom Niebuhr
« Reply #38 on: December 26, 2014, 05:34:18 AM »
Bill,
Look fantastic. The graphics look great too.
AMA 7544
« Reply #39 on: April 01, 2015, 01:45:57 PM »
I just got off the phone with Jay Smith from Model Aviation magazine. The Margaret June construction article will be in the June 2015 issue.  %^@
Offline Charles Barnes
« Reply #40 on: April 01, 2015, 09:31:03 PM »
Congrats Bill!
« Reply #41 on: May 14, 2015, 11:25:04 AM »
Margaret June is now online. Go to modelaviation.com and search Margaret June. The complete article is available for those who can't wait for the magazine.
« Reply #42 on: May 15, 2015, 05:11:26 AM »
Just read the article Bill - great job.  I would love to see more C/L racing stuff in MA.
« Reply #43 on: May 15, 2015, 01:19:38 PM »
Just printed off the article after reading it.   Now to get plans ordered.  Very well written and a great guide for getting one built and ready.   Thanks from the old DOC.
Offline Fred Quedenfeld jr
« Reply #44 on: May 22, 2015, 05:01:58 PM »
great job bill !!!
when was the last time a cl racing model was on the front cover of model aviation
fred q
« Reply #45 on: May 23, 2015, 12:15:02 PM »
Just got my plans today.   Bill did a great job on the plans and the article.   Now to get in gear.
« Reply #46 on: May 23, 2015, 07:09:51 PM »
Glad to see a racing plane article in MA, congrats. How fast does it go?
MM
« Reply #47 on: May 23, 2015, 09:40:51 PM »
85"ish". Today I turned an 8:38 for 160 with 3 pits in Houston. Good enough to win. ;D
« Reply #48 on: May 24, 2015, 01:48:46 PM »
Way to go Bill.   Were you the pit or pilot?
« Reply #49 on: May 24, 2015, 06:23:46 PM »
It was the world famous "Biscuits and Gravy" racing team. I was flying and Mike Greb was pitting. Sorry we missed you guys last week because of the weather.
