  • April 26, 2024, 02:40:59 PM
Author Topic: Fox 15X gaskets ,screws, etc.  (Read 1124 times)
Offline Steve Thornton
« on: November 18, 2014, 09:44:38 PM »
I just acquired a Fox 15X and need gaskets, screws, and glow plugs.  Any one know vendors and sizes?
Thanks for any info and help,
Steve Thornton
Re: Fox 15X gaskets ,screws, etc.
« Reply #1 on: November 19, 2014, 08:13:31 PM »
I would certainly give Fox a call on the gaskets...and they'll probably come with screws. You can hopefully get socket heads to use instead. If it comes right down to it, you can make a backplate gasket very easily. Some use postcards, 3x5 file cards, or playing cards. For the head gasket, I would guess that any .15 sized head gasket will function fine. Most .15's are really metric bore and stroke.
The glowplugs you want are SHORT reach. I would definitely NOT use Fox glowplugs. Thunderbolts, K&B's, Zinger, Merlin (from Brodak), etc., should work much better. Hot glowplugs are good, and 10% nitro with mostly castor oil will work well.  H^^ Steve
Offline dennis lipsett
« Reply #2 on: November 19, 2014, 09:50:37 PM »
The screws are 2-56 and socket head screws are available from Micro Fasteners or RTL. I had converted most of mine awhile ago but forget the exact lengths of the screws.I have spare head gaskets but no back plate gaskets.
« Reply #3 on: November 20, 2014, 07:01:11 PM »
Thanks Steve,
I have several new long Thunderbolts and some new Fox plugs but alas.....Marvin Denny gave me som good directions on fabricating a back plate gasket so I think I will be in good shape as soon as I get some short plugs.
Steve Thornton
« Reply #4 on: November 20, 2014, 07:06:48 PM »
Dennis I replaced the old screws with the 2-56 Philips temporarily until I can get more sockets from RTL...they seem to be an odd length but maybe because I haven't tightened them yet.
This engine is very old and hasn't been run for decades.  It was seized when I got it, but soaking it in fuel loosened it right up.
Thanks for the help!
Steve Thornton
« Reply #5 on: November 20, 2014, 08:39:44 PM »
Steve,
I think that they are 1/4 inch for the back plate and 3/8 for the head screws. Duke wouldn't use odd size screws that would have been foolish and expensive. Emphasis on cost.
Generally even locked screws let go with a heat applied to the screw area. Mine had been in the engine for 30 years when I changed them. My biggest break was that the screws had not been buggered as the engine was new.
Denns
Tags: Fox 15X parts
