I ran across a Primary Force ARF a couple of months ago, and I've been trying to think through converting the front end to electric power. I'm using RSM's 35-40 equivalent system and got the motor snuggled into place nicely using some 3/4x1/2x1/16 aluminum angle.
Finding a way to install the battery has proven to be a challenge.
I've considered boxing in a small pocket in the front top of the wing to support the rear of the battery, but bellcrank movement would hit the box.
I considered raising it above the wing and positioning the battery as far forward as possible, but the motor is in the way for swapping the battery out.
I considered hanging the battery between the landing gear, which looked promising until I mocked it all up and hung the plane from the leadouts. The outboard wing is noticeably kicked up, which I am sure will cause problems.
Fore and aft balance requires the battery to be very far forward, which surprised me.
At this point I'm left with two options;
1) Cut a 1"x2" square hole in the fuselage, about 1" behind the motor mount, and glue the battery box in crossways, like a canard.
2) Strip some covering off the outboard side of the nose and glue the battery box vertically to the fuselage.
Neither of these options seem like they would be aesthetically pleasing.
Is there another option I haven't considered? Maybe flat against the fuselage diagonally?
Anybody have pictures of an electric PF install?
