With the brass tube for a bearing on a steel wire rod, I wouldn't think you would have any issues with galling or any other kind of seizing. The dis-similar metals make sort of a natural bearing in itself, especially brass. If you put any kind of lubrication on it at assembly, that should make the assembly last several life times. The bell cranks only rotates a pretty limited amount, and it a back and forth motion. I don't think I have ever heard of a bell cranks locking up on a pivot wire or rod.
