Dennis, I'm certainly not the World Expert on this topic, or just about anything else control line related, but I'm pretty sure the answer is no. With conventional gear you're finding a compromise between nosing over on landing, and bouncing on landing. Grass tends to pull you into a nose-over, so you put the gear farther forward.
With trike gear, you don't have that problem, unless your front wheel is too far back. If there is a consideration with grass fields and trike gear, it's that the nose gear takes a beating, and will take more of a beating if you're flying off of grass. My current ride has trike gear, and about ever half a dozen flights I need to bend the nose gear forward.
