Big Bear, that is basically what the late Allen Brichause used to tell us at the stunt clinics. Turn at left foot, fly to right shoulder and over to left shoulder and down to right foot. Most people make the hour glass too wide and that makes it hard to do the corners.
Most people make it FAR TOO SHORT, which a second corner at anywhere from 45 to 60 degrees. Turn maybe 110 degrees, climb to 60 (which is where the tops of the round loops were), make a vague outside jog of about 30 degrees, wind up still climbing steeply. Then they get near the top of the circle, and then try to do a near 180 with no speed to try to get the 4th turn where it belongs. This almost always fails, and the airplane stalls, sometimes 2-3 times, then come more or less straight down, and then its an emergency pullout just to save it. At least that is what I see time and again. They just can't bring themselves to let the airplane climb in a straight line to the top, it's like a counter goes off in their heads at about 2 seconds, and something has to happen then.
Making it too wide is the second problem, but they do it because it's much easier to get the second corner to work, not harder. Many airplanes are not capable of doing the maneuver at the width specified and most of them can't do it in any sort of wind. Doing it wider makes the second corner easier and leaves room for recover over the top. It should get scored down, but not as much as getting blown out. This is one of those things from the other thread that isn't commonly recognized as a distinguishing item. The judges can see it, but the pilots usually have no idea why David got a 38 on his, and Joe Bellcrank got a 29 even when the bottoms are equally good, and attribute it to "halo" or something like that.
