I have a lot of theories, but no facts. How about you?
Put 1 LA46 on a profile, put another inside a built up fuse. Same everything else including stock LA mufflers with no extra "stingers" installed. At the end of a flight, the profile will have some oil on the plane, mostly behind the muffler but the built up fuse will have very large amounts of raw castor behind the muffler and covering the bottom of the fuse.
I don't know why that should be unless it is strictly a function of air flow and surface area. Anyone have any explanation? (By the way, remember taking castor oil being a remedy? Glad things have changed a bit.)
