  • May 04, 2024, 09:42:56 PM
Author Topic: Brodak Smoothie: bellcrank output hole  (Read 2264 times)
Offline kiwibrit
« on: August 31, 2014, 12:03:32 AM »
The instruction text doesn't seem to say which hole on the output arm of the bellcrank to use on my Brodak Smoothie. The bellcrank is connected by a short pushrod to the flap horn, which in turn is connected to the elevator by a longer pushrod.
A photo is not quite clear, but looking at it I think I should use the middle one of three. Can anyone confirm?
Re: Brodak Smoothie: bellcrank output hole
« Reply #1 on: September 02, 2014, 12:59:31 PM »
Don't the plans show the bell crank top view?   I usually go the closest hole to the pivot point.
Offline kiwibrit
« Reply #2 on: September 16, 2014, 01:35:37 AM »
There are no plans with the kit. I used the centre bell crank output hole.  So far the model handles well - after bringing the lines closer on the handle (compared to my Cardinal set up) - but not tried square manoeuvres yet.
Offline Bob Hudak
« Reply #3 on: September 16, 2014, 10:01:21 AM »
The ARG I built in 07' had some sort of pot metal for the horns,they started to walls out. I wound up bushing the elevator and flap horn with brass tube. The plane flies great with a Webra 32 on 60' lines. Scotch tape will hold the covering back on when it starts blowing off.
Bob
350838
Tags: Smoothie  bellcrank
