With Shark rib patterns floating around, I just want to add that the two Shark.45s that I have built were copied from the Jetco kit. Instead of building the fuselage in two pieces like the kit was assembled, I just used 3/8" wider wood for the sides and made them 1 piece. Makes for easier alignment when building. For the main landing gear, I used grooved hard wood blocks from SIG, and a similar installation for the nose gear, so that both can be removed if need be. Make sure you check on what tank you intend to use, so you can move the rear tank compartment bulkhead back as as possible. The Jecto kit had top and bottom blocks for the fuse, and everything else that need small blocks was built up from laminated balsa die cut parts. replace those with the best block that you can. For up to a ST.51, you'll need a 5 ounce metal tank, or a six ounce plastic tank. The canopy that I used was the front portion of a SIG Magnum canopy, I think. It's been 20 years since I built the first one and almost ten now since the second one was built! My two came out at 64 and 61 ounces respectively. They can probably be built a bit lighter. I want to build one more some day with a bit more modern numbers, mainly a bit larger stab and elevator, but about the same size. The Jetco kit is a little smaller that the original, and the RSM kit, and it fits my vehicles better!
Good luck and have fun,
