Heres what I got:
-Plans for Hutchinson's T-6. Around 500 squares calling for a OS40-46 or a Magnum 36, all three of which I have.
-Discussions with some folks wanting to up the motor size on their models to a 56-60.
-I have a Tom Lay ST 51 sitting on the shelf, needing a good home.
-The 51, of course is heavier (11oz vs a 7oz 40FP). However, Don's notes that came with the plans call for burying about 4oz of lead in the nose, given the short nose moment of a radial-engined airplane. The added weight would not be a factor. Should be able to build a tank to carry enough fuel and yet fit in the space provided.
-My only concern is running a bigger engine on a smaller model then what is the norm as far as getting a good run pulling a model of that size.
Thoughts?
Thanks a bunch,
Sean
