  • April 24, 2024, 07:59:39 PM
Author Topic: best motor for ARF oriental  (Read 4135 times)
Offline Chris Belcher
« on: July 28, 2014, 01:53:37 PM »
Got my Brodak ARF Oriental and have two motors i could use: LA46 and Brodak 40. Which is better...for this plane?
Re: best motor for ARF oriental
« Reply #1 on: July 28, 2014, 07:08:37 PM »
I've had the plane and flew it with the Brodak .40.   Was a good combination for me at the time.   Now I have started using the LA .46's with not problems.   I think my Brodak .40 is going on strike for me as it does not want to start or run right.  Guess it is time for a tear down and cleaning.
Online Geoff Goodworth
« Reply #2 on: July 28, 2014, 07:13:53 PM »
A Brodak 40 seems pretty happy in my ARF Oriental. Props have been a Bolly Clubman 10.5 x 5 and the APC 10.5 x 4.5.
Offline Matt Colan
« Reply #3 on: July 28, 2014, 08:05:52 PM »
A Brodak 40 will fly it, but an LA 46 will bring it to life! My grandfather had a Brodak 40 in his mustang and he had to fly it around 4.9-5.0 lap times. He put an LA 46 in it, and the plane flies much better than it did with the 40 and at a slower speed as well.
We run the LA 46 with a 12.25-4.25 carbon fiber prop turning about 9600RPM with a 40LA size Venturi (Randy Smith told us this and it worked out great!). It's a pretty bulletproof combination for us.
« Reply #4 on: July 29, 2014, 09:28:45 AM »
What about balance issues? Has anyone had to add lead to the tail using the LA46?
Offline Matt Colan
« Reply #5 on: July 29, 2014, 03:09:46 PM »
Here are the weights of the 40 and the LA46.
Brodak 40: 8.5 ounces (with muffler)
LA46: 9.3 ounces
You can get lightweight tongue mufflers if you are worried about the balance on the airplane. The airplanes we've had the LA46 in have balanced out fairly well. I had one in my Vector 40 and I needed to add some tail weight to get it to turn more to my liking (part of it was my own fault in putting the plane together).
Offline Jared Hays
« Reply #6 on: September 03, 2014, 12:32:39 AM »
Mine is powered by a Super Tigre 46
Offline DanielGelinas
« Reply #7 on: September 16, 2014, 05:28:56 PM »
I would go with the b40. Actually, that's what i did with mine. Used with tongue muffler, did not add tail weight. It flies great!
Try it. If you don!t like it, put the la46 on it. I believe its the exact same mounting pattern!  The b40 you can set about 3/16" further back, which to me is an advantage.
You can't go wrong either way.
Dan
