The engine is charged with fuel, and may flood because there is no restriction on the fuel. Then the engine can draw air through the fuel line, and the venturi, so it can burn off the fuel charge going more lean than expected.
If speed is the name of the game, pressure feed systems such as bladders, and large bore venturies make for screaming engines. Start on prime then let the fuel run! As venturi bore size increases ease of starting decreases, until it reaches a point of impossible after passing through really annoying.
A couple of Cox TD engines a .049 and a .051 arrived with over-bored intakes, much larger than recommended. Swapping to stock suits my desires and needs much better than having nearly impossible to operate engines. (I like one and two flip starts)
Phil
