after being the controlline ED at the nats for at least 6 years i can tell u it takes a while to figure things out ,then add some rain, wind ,and it is an all new ball game
in my opinion Allen and his crew worked very hard and put in a lot of time to put on a good event but tried to do the impossible even without the weather ( OJT ) they had about 40 flyers flying 5 events on two circles and keep a time schedule ,as they and we found out ,it just ain't going to happen , too many twosomes helping each other and having to fly on both circles ,being called to both circles at the same time ,except for the weather it would have worked itself out in the end and i believe everyone would have gotten their flights in. .maybe we need another day of flying .
one thing we learned racing is that if you give a flyer extra time on the clock at 8 AM to be FAIR you have the give the flyer at 11AM ,1PM .so on and so on and then it is dark. and u cant please everyone so u just do what u feel is right. the ED cant take anything personally but it still is not fun when you have to DQ your best friend for something he did or didn't do.but it is part of your high paying job, and he needs to accept that u are just doing your job.i have had to DQ my flying partner
there needs to be some time set aside to make sure everyone is using the correct lines as there was a problem with someone not realizing that his lines were too long and it didn't come to light until after the flight. there is no way you can take all the fragile ships the one spot to check lines but two lines painted the length of the pits 70 ft apart would do the job the line puller could just observe that are ok or long with very little trouble
as a newbie to scale the Friday nite meeting was a big help as there was things that i still didn't know so keep up the good work and see u at Brodaks
