Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
---->Stunt News click here<----
May 10, 2024, 05:51:18 PM
1 Hour
1 Day
1 Week
1 Month
Forever
Open Forum
(Moderators:
RandySmith
Steve Berry
Johnson Stunt Supreme Displacement?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Johnson Stunt Supreme Displacement? (Read 1074 times)
Bill Little
2017
Trade Count:
0
Admiral
Second in COMMAND
on:
July 05, 2014, 02:27:21 PM »
Hi All,
What is the actual displacement of the Stunt Supreme? I have heard they are a little less than ".35". If so, what is it, actually?
Thanks!
BIG Bear
RNMM/AMM
Logged
Big Bear
AMA 95351 (got one of my old numbers back!
steve bittner
Trade Count:
0
Lieutenant
Re: Johnson Stunt Supreme Displacement?
Reply #1 on:
July 05, 2014, 03:26:56 PM »
It is a 35 bore .770 stroke .750 compression 6.5-1 weight 7.6 oz
Logged
Bill Little
2017
Trade Count:
0
Admiral
Second in COMMAND
Reply #2 on:
July 05, 2014, 04:27:25 PM »
Quote from: steve bittner on July 05, 2014, 03:26:56 PM
Thanks, Steve. I had heard of a .32 or .33 that was said to be an SS and I knew some of the guys here would know.
Thanks!
BIG Bear
RNMM/AMM
Logged
Big Bear
FLOYD CARTER
24 supporter
Trade Count:
0
Admiral
Reply #3 on:
July 05, 2014, 04:35:35 PM »
WHEW! That's a relief! Now you can put it in a real big plane.
F.C.
Logged
90 years, but still going (mostly)
AMA #796 SAM #188 LSF #020
steve bittner
Trade Count:
0
Lieutenant
Reply #4 on:
July 05, 2014, 06:59:44 PM »
Johnson had an engine stamped 32 on the side, then early stunt engine with a plain single S stamped on it. Im using a Johnson 35 in a 59 inch wing span Hi Johnson stuka. It pulls the plane very well about 80/85 thru all the manuvers. If you use a muffler it may kill the power though.
Logged
Garf
Trade Count:
0
Admiral
Reply #5 on:
July 06, 2014, 11:51:29 AM »
Try this:
Logged
"SAVE ALL THE PIECES"-Phil Brown
http://hangarflying.proboards.com/index.cgi?board=wire
Print
Pages: [
1
Go Up
« previous
next »
Open Forum
(Moderators:
RandySmith
Steve Berry
