I remember seeing a large stunt ship with a push rod hooked to the rudder , but did not get any info on it . are the rudders on some of these large stunt ships working with the elevator ? and is there any benefit to this kind of set up?
What you most likely saw is a Rabe Rudder. Named after Al Rabe who either invented the actuation method or at least used it with great success to win a lot of stunt championships with very scale like, very competitive stunt planes.
It is coupled on short control horns to the elevator in an offset manner to allow adjustment and biased control of the rudder as elevator control is given. It's aim is to overcome the effects of precession that tend to make the airplane yaw in one direction with up elevator and the other with down elevator. The rudder overcomes the yaw effect if properly adjusted and you hold your mouth just right.
Everyone agrees that they work. Not everyone agrees that they work well. They seem to be more effective on some airplanes than others, and can be a real headache to get properly adjusted...hence the mouth holding comment!
You can learn all the details about them here on the forum simply by searching for Rabe Rudder...there are tons of discussions about them. Some from the Master himself Mr Al Rabe!
Some use adjustable hinged rudders that are simply coupled to a push rod ridgidly fixed to the fuselage, and can be adjusted by means of a screw thread on the pushrod.
