Last Summer, Bill Smith and I started working with Wen Mac engines (probably as a flashback to our youth!). Bill is using a Mk II to power a Firebaby replica.
I started working with the later 'Hot Shot' versions and have a selection of Mk XII through Testors-McCoy. The glow heads are not easy to find, and I use Merlin drop-in plugs almost exclusively in my Cox and Norvel engines, so I thought I would make a head clamp for the Wen Mac and compare the Merlin plug against the 2 generations of Wen Mac glow heads in my stock.
The tests were conducted with a Cox 6x3 prop and Sig 15% Champion fuel. Other folks have done similar tests with smaller props, so they recorded higher rpm. I recorded a max of 14,700 rpm using a Merlin plug. That's not bad swinging a 6x3 prop
Fred
