Juan, I hope this not more information than what you asked for but here is the method I use. To cover an open bay wing.
I lay a large terry cloth towel out flat. Then I lay the panel,of silk span on the towel, smooth it out as much as I can and then mist it with a spray bottle of water. I soak the tissue well. Take the back half of the towel and fold it over the silk span and press down to absorb most of the water. Lay the tissue over the half o the wing you are covering and work as many wrinkles out as you can. Before I do any of this, I have 3-4 coats of dope thinned 50/50 on the air frame and saned smooth.
OK back to covering. Once I get all the wrinkles I can out of the damp tissue, I brush around the edges of the silk span with thinner only. You can used thinned dope to do this but I usually just use thinner. If I have a spot that is not sticking down, I stick my finger in dope and rub it in through the silk span. When the tissue drys and shrinks, I start brushing thinned dope until I fill the tissue and it becomes drum tight. The last couple of coats has Zinc Sterate in it to fill better .
If you are using the new silk span from Brodak, check each side of the sheet for a rough and smooth side . Make sure the smooth side is up.
Hope this helps.
