Thought I would fire up the O&R 23FR today but not having any luck. I had a O&R Side port when I was 12 years old running as a sparky later changed to glow and it would run at will. All I get is a tired arm and a few pops. I did get one engine run but took a lot of cranking. I'm running home brew 25% Sig castor and 75 % methanol. The prop is a 9-4 wood. The engine is tight with good compression and very little actual run time. Very slight sign of bolt mounting on engine lugs. In fact engine appears to be new. This engine was a gift from a friend. It is pictured in my Dynamic post. The needle valve has two holes so I checked for dirt and it is clean so I installed the needle with one hole facing forward and the other facing aft. I started at three turns out and only got it to run one tank out with the needle four turns out. I did not try to adjust needle in do to the exhaust next to the needle. May have to make an extension. Any thoughts from you folks. My starting procedure is fill tank , give a choke to see fuel entering venturi, prime in exhaust turn prop by hand a couple flips, attach glow driver and bring prop up to a bump and flip by hand. I don't feel I should use a electric starter on these old engines. I should mention that the glow plug lights up great, not sure the brand ,appears to be a OS. Richard
