When you use a hard point handle, you need to make an assortment of different length line clips , to adjust the handle neutral.The commonly used ones look something like paper clips. The "Hello Kitty" line clips are the most deluxe type you can use, and they provide maybe an extra measure of security. They come in a set in about 1mm increments , and there is no way the line can be accidentally unfastened.They are a bit more expensive than making your own , but they will probably last your lifetime, and you can be proud to use them. I sure do.Buy them from Randy Smith at "Aero Products".
