  • April 26, 2024, 01:53:08 PM
Author Topic: Pictures of YAK 9  (Read 2408 times)
Mike Griffin
Pictures of YAK 9
« on: October 28, 2013, 02:56:30 PM »
Thanks to Steve Thomas for sending me these pictures.  This is the YAK 9D kit i sold a couple of years ago and these are the first pictures I have ever received of a build.  THought you might like to see them.
Offline Steve Thomas
Re: Pictures of YAK 9
« Reply #1 on: October 29, 2013, 12:50:30 AM »
Here's a couple more for you, Mike. I don't really have the skill or patience to do a finely-detailed cockpit, so it's fairly simple. The reflector sight is just a bit of piano wire with a scrap of SLC ironed onto it.
Covering and doping is all done now, so with any luck I'll get some primer onto it tomorrow before I go to work.
Mike Griffin
« Reply #2 on: October 29, 2013, 08:48:21 AM »
Thank you Steve.  Looking good.
« Reply #3 on: October 29, 2013, 09:38:40 AM »
Looks great.   Makes me to want to clear the shop and start on mine.   But, I have committed to three Ringmaster builds and one refinish.
« Reply #4 on: December 03, 2013, 06:02:17 PM »
Here's the finished item. Well almost finished - it still needs the hinges sealed, and some eyelets on the leadouts might come in handy.
Engine: T&L ST.46
Prop: Eather 12x5.75, cut down to 11"
Tank: 6oz plastic clunk
Weight: 47oz
Paint: Tamiya acrylic, with KBS Diamond clear (and Bondall Monocel marine varnish*) over the top
Mike did a great job on this kit, and it was a really enjoyable build. I didn't have to change much. I made the cockpit cutout too wide for the supplied canopy, and ended up making my own; and the top of the fuselage ended up planked rather than the way the plans showed. Otherwise it's all standard as per the kit.
I'm about to go away for a few weeks, and the clear needs time to cure, so I'll fly it some time in the New Year.
* For KBS users: I really like the stuff and found I could airbrush it without having to thin it excessively.  Problem was that when I went to apply a second coat, it just beaded up like water on a freshly-waxed car.  When I RTFI I found that the second coat is supposed to go on within 6 hrs of the first  HB~>.  Hence the marine gloss to finish it off.
« Reply #5 on: December 03, 2013, 06:26:52 PM »
 Looks great! No red stars on the top of the wing though? ???
« Reply #6 on: December 03, 2013, 06:47:32 PM »
No, oddly enough, the real thing almost never had them.
« Reply #7 on: December 03, 2013, 07:40:05 PM »
 Hmm, I guess I've never noticed that about the Russian birds. Great looking model Steve, and worthy of a nice aluminum spinner!  S?P ;D
« Reply #8 on: December 03, 2013, 07:47:10 PM »
Thanks Wayne. If the consensus was that it'd be better with stars on the wings, I could easily put some on. Not changing spinners though - if you look closely, this one's got a cannon in it, which I'm rather proud of.  ;D
Offline Mike Keville
« Reply #9 on: December 03, 2013, 07:48:43 PM »
Here in Arizona, Leroy Black flies a beautiful Yak-9 from the kit.  Wish we had some photos, although he doesn't post here.
« Reply #10 on: December 03, 2013, 08:00:47 PM »
 Heck, I'd say go for adding the stars then. That might be a problem though if all your other graphics are already under the clear?
 I thought I could see something extra sticking out of the spinner, allen bolt or...? If so, that will work in an aluminum one too.
« Last Edit: December 03, 2013, 09:11:55 PM by wwwarbird »
Offline 55chevr
« Reply #11 on: December 03, 2013, 09:09:18 PM »
Go ahead ... add the stars ...
Joe
Joe Daly
Mike Griffin
« Reply #12 on: December 04, 2013, 06:03:43 AM »
Steve what a magnificent job you have done on this.  This makes me very proud of the kit and of the wonderful job you did of building it and finishing it.  Thanks so much for the pictures and I hope this will inspire some of the folks that bought this kit to pull it out of the closet and build it.  The kit is still available by special order.
Thanks again
« Reply #13 on: December 05, 2013, 04:29:02 PM »
Steve,Brother your doing some beautiful work there.
« Reply #14 on: December 08, 2013, 01:35:16 AM »
Thanks all for the very kind comments. Wayne and Joe, I've added the inauthentic stars.  I reckon you're right - it looks better with them, so I appreciate the feedback.
(The 'cannon' is just a bit of CF tube epoxied into a carefully-prepared spinner cone.)
ChrisSarnowski
« Reply #15 on: December 08, 2013, 07:18:43 AM »
Looks great Steve, nice work!
-Chris
