  • July 03, 2025, 08:13:34 AM
Author Topic: PA 65 bearings  (Read 1509 times)
PA 65 bearings
« on: September 16, 2013, 04:28:02 PM »
      Hello
                  I would like to know the part number for the bearings on a PA 65. I took it apart and the front has number 698RS but didn`t find a number on the rear bearings,all responses appreciated.
Re: PA 65 bearings
« Reply #1 on: September 16, 2013, 05:29:18 PM »
I would give Randy Smith a call...betcha he knows! 8)
Online Dallas Hanna
Re: PA 65 bearings
« Reply #2 on: September 16, 2013, 08:13:08 PM »
      Hello
Juan, this is the size but quality unknown.:
http://www.ebay.com/itm/1-698-2RS-Premium-seal-698-2rs-bearing-698-rs-bearings-698-ABEC3-C3-/140752212646?pt=BI_Heavy_Equipment_Parts&hash=item20c57c52a6#ht_953wt_1075
HH
« Last Edit: September 17, 2013, 03:39:25 PM by Dallas Hanna »
Re: PA 65 bearings
« Reply #3 on: September 17, 2013, 10:02:55 AM »
When I did my 65 I contacted Boca Bearings and the guy knew exactly what I needed.  The price was reasonable, too.
Re: PA 65 bearings
« Reply #4 on: September 17, 2013, 01:53:29 PM »
and you get what you pay for, cheap bearings not Spec ed  for the PA will not perform as well, and the inferior front sealed bearing will leak very badly, many times from the start, The ones I use are special quad seal bearings, and work way better than the cheap 3 dollar ones I can buy, the rears are also a special spec and are hi speed Phenolic bearings that have the correct clearance.
I do not sell cheap ones, but do sell the correct ones , they do also have to be pressed on the shaft and then pressed into the case with a contersunk pusher for the front, and a collector for the rear.
www.aeroproduct.net    678 407 9376
Online Dallas Hanna
Re: PA 65 bearings
« Reply #5 on: September 17, 2013, 03:39:56 PM »
As Randy says, "you get what you pay" for Juan.   The link was for the purpose of the bearing number/size info to purchase an equivalent good quality bearing.
HH
