  • April 18, 2024, 07:26:16 AM
Author Topic: Two wheel landing gear.  (Read 3461 times)
Offline John Desrosiers
« on: July 21, 2012, 03:26:59 PM »
Two wheel landing gear on a flite streak? What shouldI use for a fuel tank? The engine is an old fox 36. thanks
Re: Two wheel landing gear.
« Reply #1 on: July 21, 2012, 07:17:38 PM »
Wouldn't 2-wheel gear make it ineligible for Nostalga 30?
Where did you fit a 4 ounce tank on a Flight Streak?
« Reply #2 on: July 22, 2012, 08:33:00 AM »
We fly for fun only, no comp. I just do not like a single gear.
« Reply #3 on: July 22, 2012, 10:28:07 AM »
Then if you want nice looking takeoffs and landings, putting a two wheel gear onto the thing does a world of difference.
Offline Joseph Lijoi
« Reply #4 on: July 23, 2012, 10:59:11 AM »
Brodak makes a tank that will fit.  I think the 3 1/2 oz profile wide wedge will work.  You will have to revent so that pick up tube is flush with the front of the tank.  Move the engine as far forward as reasonable.  Kraft Hayes makes a 3 oz plastic tank, but I think this is no longer available.  The Hangar 9 PT 19 CL will fit if you have one it is about 2 7/8 oz.
Brodak 38 Special aluminum gear works well and is pretty light.  You will need a spacer to keep the screw heads from puncing a hole in your tank.
« Reply #5 on: July 23, 2012, 12:00:43 PM »
I bought some of those from Brodak this spring, so they were at least available then.  Check their catalog.
Offline rustler
« Reply #6 on: July 23, 2012, 02:17:11 PM »
Did you get to fly against Mr. Grondal and his modified Nobler or Mr. Gabris with his "Master"?Bill
Hi Bill. We'd have to check the entry list, but I'm sure the answer is yes. But they may not have noticed me! It was a great adventure, I'll PM you with some more details.
Ian Russell.
« Reply #7 on: July 24, 2012, 08:49:51 AM »
Thank all for your help. I,ll shop around for an older 3 once wedge tank.
