  • April 26, 2024, 09:19:55 PM
Author Topic: New Carbon Fibre Bell Cranks  (Read 4963 times)
Offline eric rule
« on: July 20, 2012, 09:00:21 PM »
The machine shop finally delivered my 4" Carbon Fibre Bell Cranks.
They are CNC machined from commercial grade 1/8" thick carbon fibre sheet. This means there are no "voids" in the material that you often get with hand layered carbon fibre. The bushing is a high tech material similar to what is used in computer hard drives. It has a very low coefficient of friction so movement is silky smooth. We bush the line end holes with brass so that you do not have to bend tubing.
Cost is $19.99
Re: New Carbon Fibre Bell Cranks
« Reply #1 on: July 20, 2012, 10:24:47 PM »
What are the dimensions?
Offline eric rule
« Reply #2 on: July 27, 2012, 05:42:51 PM »
Hi Milton;
The bell crank is 4" between the eyelets. Material is 1/8" thick commercial CF sheet.
Regards
Eric
« Reply #3 on: July 27, 2012, 06:25:15 PM »
Looks good, Eric!
