stunthanger.com
CLICK HERE---->    <----CLICK HERE
Welcome, Guest. Please login or register. May 25, 2013, 10:40:10 PM
Pages: [1]   Go Down
  Print
Author Topic: New Carbon Fibre Bell Cranks  (Read 1046 times)
eric rule
Moderator
Trade Count: (0)
New Pilot
Rate User 0
Offline Offline
« on: July 20, 2012, 09:00:21 PM »
The machine shop finally delivered my 4" Carbon Fibre Bell Cranks.
They are CNC machined from commercial grade 1/8" thick carbon fibre sheet. This means there are no "voids" in the material that you often get with hand layered carbon fibre. The bushing is a high tech material similar to what is used in computer hard drives. It has a very low coefficient of friction so movement is silky smooth. We bush the line end holes with brass so that you do not have to bend tubing.
Cost is $19.99
Logged
proparc
Trade Count: (0)
Admiral
Rate User 3
Offline Offline
« Reply #1 on: July 20, 2012, 10:24:47 PM »
What are the dimensions?
Logged
eric rule
Moderator
Trade Count: (0)
New Pilot
Rate User 0
Offline Offline
« Reply #2 on: July 27, 2012, 05:42:51 PM »
Hi Milton;
The bell crank is 4" between the eyelets. Material is 1/8" thick commercial CF sheet.
Eric
Logged
Bill Little
Trade Count: (0)
Admiral
Rate User 142
Offline Offline
Second in COMMAND
« Reply #3 on: July 27, 2012, 06:25:15 PM »
Looks good, Eric!
Logged
AMA 95351 (got one of my old numbers back! Grin )
Pages: [1]   Go Up
  Print
Jump to:
