CLICK HERE---->    <----CLICK HERE
Welcome, Guest. Please login or register. June 18, 2013, 04:52:35 PM
Pages: [1]   Go Down
  Print
Author Topic: What do you use in your ultrasonic cleaner?  (Read 466 times)
frank mccune
Trade Count: (0)
Ensign
Rate User 0
Online Online
« on: May 22, 2012, 10:49:42 AM »
     Hi:
      What works well in an ultrasonic cleaner to clean engines?
        Tia,
        Franchi
Logged
RandySmith
Moderator
Trade Count: (0)
Admiral
Rate User 33
Offline Offline
Welcome to the Stunt Hanger.
WWW
« Reply #1 on: May 22, 2012, 11:25:57 AM »
     Hi:
        Tia,
        Franchi
NOt much will work there, if you want to clean the engine buy a gallon can of Berrymans carb cleaner, it has a dip tray and work great.
You can also use antifreeze in a crock pot and that will also clean the parts of your engine
Logged
RandySmith
Moderator
Trade Count: (0)
Admiral
Rate User 33
Offline Offline
WWW
« Reply #2 on: May 22, 2012, 11:28:28 AM »
By the way Ultrasonic cleaners are  really the best way I have ever found to clean drafting pens such as the RapidOgarphs or any technical drawing pen that you use India inks in
Use it with a solution of Simple green, best way I have ever found to clean things like pens
Logged
Allan Perret
2013 Supporter
Trade Count: (0)
Admiral
Rate User 0
Offline Offline
« Reply #3 on: May 22, 2012, 11:32:51 AM »
What is the cleaning agent in antifreeze ?
Logged
Allan Perret
AMA 302406
Slidell, Louisiana
Tom Niebuhr
AMA Member
Trade Count: (0)
Admiral
Rate User 28
Offline Offline
« Reply #4 on: May 22, 2012, 11:46:48 AM »
Rapidograph pens can also be ultrasonic cleaned using Windex. This was recommened to me by a drafting supply business.
Logged
AMA 7544
RandySmith
Moderator
Trade Count: (0)
Admiral
Rate User 33
Offline Offline
WWW
« Reply #5 on: May 22, 2012, 01:31:07 PM »
Yep did that, except simple green works about 50 times better and faster  :-)
Logged
Brian Hampton
Trade Count: (0)
Commander
Rate User 0
Offline Offline
« Reply #6 on: May 22, 2012, 09:10:13 PM »
I use CLR Oil and Grease Remover....it comes in the black bottle.
Logged
50+AirYears
Trade Count: (0)
Commander
Rate User 0
Offline Offline
« Reply #7 on: May 29, 2012, 12:43:06 AM »
Just cleaned a few engines tody using something I read about in an FM a few years ago.  Dawn Power Disolver.  Spray it on, let set 4 or 5 minutes, and brushed it off with an old toothbrush and soapy water.  Cleaned off 20_ year old Castor based crud and dirt.
At work, we always filled the US cleaner with water, then put the items or circuit boards to be cleaned in a separate container with usually Isopropyl Alcohol.  The cleaner's manual had several warnings against puting ANY flammable liquid direct into the tank.  And for best results, the water level had to be at least up to the fill line, to make sure the liquid level was higher than the top of the Tranducer(s).
Logged
Tony
RandySmith
Moderator
Trade Count: (0)
Admiral
Rate User 33
Offline Offline
WWW
« Reply #8 on: May 29, 2012, 02:17:25 PM »
Caution...Power Dissolve will rust and corrode any iron,steel, parts or any other metal that will rust, it will also corrode your alum9num parts,
I have seen this several times with people that used Power Dissolve,  SO make sure you completely take the engine apart, rinse every part well, and then make sure you oil the parts very well before putting the engine back together
Logged
Pages: [1]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines
Valid XHTML 1.0! Valid CSS! Dilber MC Theme by HarzeM
