Hello again,
Randy still has stock ABC and his special AAC P/L liners for the OS 46VF (at least I think that was what he said?). This got me thinking about the two types of P/L setups. I know that you need a special piston alloy (hypereutectic aluminium / silicon alloy) to match the expansion of the brass cylinder liner.
The hypereutectic alloy seems to be expensive and not all that readily available, so why do most manufacturers stick to ABC (or ABN) setups? It would seem logical to use the AAC system where both piston and cylinder should have similar expansion coefficients...
Andrew,
You assumption about materialrequirements is wrong. AAC system does not work if both piston and liner are made of similar alloy, piston must have a smaller expansion coefficient.
Classical rule is that there should (in AAC) be a difference of 10...12% in the Si contents of piston- and cylinder alloy.
Normally for the cylinder, the alloy with best thermal stability is chosen. Usually this means an eutectic mix of Si in alloy, which is something around 10..12%. And of course the chromium plating requirements must be considered too.
So, for piston, the Si requirement is about 20%, but in modern engines with more power and "pinch" even more depending of running requirements. Even 30% Si consentration is used in some cases, like in our MB stunt engine.
High Si content is also good for friction coefficient against chromium.
Regards from Kiev, Lauri
