stunthanger.com
CLICK HERE---->    <----CLICK HERE
Welcome, Guest. Please login or register. May 23, 2013, 12:58:41 AM
Pages: [1]   Go Down
  Print
Author Topic: Organizer For Wire, Rods and Tubes  (Read 464 times)
Dick Pacini
2013 Supporter
Trade Count: (0)
Admiral
Rate User 2
Offline Offline
My Work Vehicle
« on: May 10, 2012, 07:33:43 PM »
I had piano wire, carbon fiber tubes, arrow shafts,  brass, aluminum and copper tubing spread out all over.  My shop is small, so I needed to choose a spot and dedicate it.  I had several scraps of PVC pipe and conduit that were available.  I cut the pipe to different lengths, to accommodate the lengths of material I needed to store  I had a little nook in the basement wall that was the perfect size.  I glued up the PVC pipe with rubberized CA from Bob Smith and added a plywood bottom shaped to fit the nook in the wall and the bottom of the pipes.  It worked out perfectly.  All my tubes and wires are safe and in one place.  I like it!
« Last Edit: May 10, 2012, 09:24:01 PM by Dick Pacini » Logged
AMA 62221
Once, twice, three times a lady.  Four times and she does it for a living.
Ty Marcucci
2012 Supporter
Trade Count: (0)
Admiral
Rate User 51
Offline Offline
« Reply #1 on: May 10, 2012, 08:18:41 PM »
How much do you want to bet than soon, very soon, you will have a large heavy "thing" in the way of that nook...  Never fails. I have more stuff behind other stuff.  For my wire, tubes, etc I use peanut jars. Then I can see what is hiding at the bottom. Usually dead spiders. Layingdown Layingdown Layingdown
I like your idea. I think I'll steal it. There, now it's mine. Hoff Layingdown Layingdown y1
Logged
Ty Marcucci
Dick Pacini
2013 Supporter
Trade Count: (0)
Admiral
Rate User 2
Offline Offline
My Work Vehicle
« Reply #2 on: May 10, 2012, 09:22:45 PM »
Nope, no heavy things.  The room is small, 8 X 11, so I am making use of the walls.  I have two benches in there now, one against (and full width) the wall and my building bench which 20" X 60" which is on wheels, so I can move it around as needed.  I am still working on it every day, organizing and putting things into little plastic drawers in three organizer cabinets.  However, I have a Coyote on the bench which is moving along nicely.  Wing is almost done and the tail feathers are hinged and sanded.
Logged
AMA 62221
2013 Supporter
Trade Count: (0)
Captain
Rate User 4
Online Online
« Reply #3 on: May 10, 2012, 10:12:54 PM »
Great idea Dick.  I like it so much I'm gonna steal it and make one for myself...
Logged
Joseph Patterson
2012 Supporter
Trade Count: (0)
Commander
Rate User 1
Offline Offline
AMA member- Supporter
« Reply #4 on: May 11, 2012, 08:30:35 AM »
  Thanks Dick, neat and very compact. I'm gonna steal it too!!
       Doug
Logged
Bill Little
Moderator
Trade Count: (0)
Admiral
Rate User 142
Offline Offline
Second in COMMAND
« Reply #5 on: May 11, 2012, 05:30:49 PM »
I've been using the red cardboard tubes the K&S wire and tubing comes in.  I like the plastic pipe idea better!
Logged
AMA 95351 (got one of my old numbers back! Grin )
Jim Fruit
Trade Count: (0)
Commander
Rate User 1
Offline Offline
« Reply #6 on: May 11, 2012, 06:27:51 PM »
Great innovation, Dick. I know what you mean about loose pieces of wire. I have all of mine laying on one flat shelf. What a mess. I have used the red cardboard tubes like Bill also. Usually wound up with forty two different sizes of wire in the tube that I had to pour out to see what was there. Thanks for sharing your idea.
Jim Fruit
Logged
Dick Pacini
2013 Supporter
Trade Count: (0)
Admiral
Rate User 2
Offline Offline
My Work Vehicle
« Reply #7 on: May 11, 2012, 06:53:07 PM »
As you can see in the pix, I have an assortment if items in each pipe.  There is enough room to visually shop, so I can get by with a setup the way it is.  If it should ever get so crowded with one of anything, I can always glue on more pipes.  I could have gone crazy and had a pipe for each class of item, but it would have looked like a "pipe organ."
Logged
AMA 62221
Pages: [1]   Go Up
  Print
Jump to:
