  • June 20, 2025, 11:02:23 AM
Author Topic: What about electronic pitch gauge?  (Read 4427 times)
« on: April 14, 2012, 07:51:36 PM »
I think someone wanted to mearure pusher props and needed reversed pitch gauge ... but what about electronic pitch gauge? it works well both directions :- ))))
and it can also easily measure motor offset, stab incinece etc ...  VD~
first pic: measuring pitch at station 6cm where the pitch is 135mm = 5.3"
second: level meter shows -5.1 deg from "calibrated" position ... means it can be calibrated to wing level and then it can show angle of motor regarding that calibrated position
it uses accelerometer for measuing, gravity for reference and Jeti Box for displaying  H^^
Offline Keith Renecle
Re: What about electronic pitch gauge?
« Reply #1 on: April 15, 2012, 12:12:42 AM »
Now that's a good idea.....Well done Igor! When can we get some??
Keith R
Keith R
« Reply #2 on: April 15, 2012, 01:05:13 AM »
if I convert it to usefull product, I will bring you one to Bulgaria :- ))))))
« Reply #3 on: April 15, 2012, 01:45:40 AM »
hmmm ... I see I posted wrong second picture ~^
so again that proper one ... it is that which belongs to text:
"level meter shows -5.1 deg from "calibrated" position ... means it can be calibrated to wing level and then it can show angle of motor regarding that calibrated position"
and the second picture shows how to measure motor offset :- ))))))))
« Last Edit: April 15, 2012, 05:59:02 AM by Igor Burger »
« Reply #4 on: April 15, 2012, 06:43:12 AM »
That is a fabulous idea!
Online Crist Rigotti
« Reply #5 on: April 15, 2012, 07:47:21 AM »
Igor,
You're gonna get rich selling it!   :)
Offline Darkstar1
« Reply #6 on: April 15, 2012, 08:35:43 AM »
Igor,
Do you write the software for that or does Jeti? Of course that's a really good idea.Especially useful for adjusting thrust lines in case theres some small goof up HB~> in building.
Later,
Evolve or get left behind!
« Reply #7 on: April 15, 2012, 08:41:38 AM »
Thanks guys, yes it is my software, Jeti Box is simply terminal with 2 lines and 4 buttons, nothing more, so I use it for alll my devices, and this is simply byproduct in the same hardware I use for active motor regulation, simply I needed exact pitch gauge and this was easier for me than making mechanic pitch gauge :- ))))
Offline Tania Uzunova
  • It's something more about gravity ...
    • www.indoorgeebee.com
« Reply #8 on: April 15, 2012, 09:34:44 AM »
Igor that  will work for all types of props? or it's calculated for tree blades? (i am sorry if question is stupid ) but i go wrong little bit because it's for something what you use, but no everytone at all? :(
Always support the inovations, especially that one which are not just stays like idea, but also can be use in the practice!
« Reply #9 on: April 15, 2012, 01:58:10 PM »
number of blades does not play role, you must fix the prop somehow, then calibrate the root of prop (you must put sensor to root and push a button) and then you can see pitch on every station .. just put sensot to station, click button which station it is (step by 10mm) and it will show you pitch on display in mm and inches
it is instead of relatively large mechanical pitch gauge on picture
Offline Steve Hines
« Reply #10 on: April 15, 2012, 09:17:33 PM »
could you do this with a digital incidence meter, it comes off and you can zero it and then put it on the blade. The only thing you would need to know is how to go from degree's to pitch. The other thing is Horzon has a pitch gage for heli. would this work.   Thanks Steve
« Reply #11 on: April 16, 2012, 12:05:18 AM »
Very clever, Igor.  You beat me to it.
« Reply #12 on: April 16, 2012, 05:41:44 AM »
Thank you Igor, after the picture now for me is much more clear : ))))  :! ( just miss some knowedge )  ::)
Offline BillLee
« Reply #13 on: April 16, 2012, 06:15:54 AM »
Hello, Igor;
Yes, very interesting!
Looks to me like the calibration to a baseline and then holding the prop solidly to that baseline is extremely critical to the operation of the device.
I could imagine a version that: a device attached to the baseline that constantly measures its orientation to gravity, and then a second as you have already shown to measure the angle on the prop, software to compute and display the difference.
Using the current Prather-style gauge like the one in your picture (baseline calibration attached) and a mechanical device on the arm to hold the measuring probe to measure the chord line of the prop.....
Well, ......  :)
Bill Lee
Bill Lee
AMA 20018
« Reply #14 on: April 16, 2012, 08:07:42 AM »
theoretically it is possible, but there are two problems:
1/ those devices are relatively large, while my sensor weights only 1 gram or so, so it is very easy to put on narrow, soft and flexible blade like APC props have
2/ yes I can make table of pitch relative to angle but it is not so neat, the beauty and reason why I decided to do it is, that in reality I not need to mess with tangents and angles, because accelerometer gives two vectors, and all I must do is simple division and it already gives tangens  VD~ ... so I need just to multiply it by radius, put to proper dimmension and I have pitch :- )))))) ... tangens is not trivial function for such small 8bit risc processor, but result was so small that I had anyway enough space in memory and I anyway did that function, so it can show slope so it allows to measure motor offset etc :- )))
« Reply #15 on: April 16, 2012, 08:20:21 AM »
Yes I know what you mean, however I did not feel troubles yet. Such a 3 blade prop from picture seats well on desk without any fixature and when I measure 2 blade prop, I simply fix it to vice and all works easy :- ))))
I have actualy only one day experience, I will see, may be I will modify it later as I will see weak points.  :)
Offline Mike Anderson
« Reply #16 on: April 16, 2012, 08:44:36 AM »
Since most will not have the Jeti box, is there another diplay that would work?
Mike@   AMA 10086
Central Iowa
« Reply #17 on: April 16, 2012, 08:54:05 AM »
Sorry, no, all my devices work with Jeti Box (timers, sequencers, active regulators etc), it is so universal, that I have no reason to use anything else. It is worth of that money :- )))) ... I cannot imagine to use electric without jeti box :-))) it is programmer for all Jeti devices, servo signal generator and monitor ... and it is usefull also as display for such devices
« Reply #18 on: April 16, 2012, 09:52:56 AM »
I did few pictures how it works:
#1: prop (marked as 5.1") with marked stations 80, 100, 120 and 140 mm
#2: button down calibrates sensor
#3: sensor moved to station 80, display shows from left: station 80 , pitch 127mm and equivalent pitch 5.0"
« Reply #19 on: April 16, 2012, 09:54:29 AM »
#4: 2x right click changes station on display to 100
#5: and then sensor moved to station 100 and display shows station 100, pitch 132mm/5.1"
#6,7: the same procedure and measuring at stations 120 and 140
it goes easy and quick even with photoshooting under hands  :- )))
Offline schuang
« Reply #20 on: April 16, 2012, 05:05:11 PM »
Igor,
This gives me an idea to use Ipod to do the same thing.  There is a program called "slope finder" which can measure down to 0.1 degree...
Sean
« Reply #21 on: April 17, 2012, 01:17:39 PM »
That's very cool.
« Reply #22 on: April 17, 2012, 01:37:14 PM »
I like it a lot,, great I idea,,
incidentally, is that a Xoar wood three blade?
« Reply #23 on: April 18, 2012, 02:58:47 AM »
Like designer i can do only drawins ;P ))) So that Pitch Gauge must be look something like that : )))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))
« Reply #24 on: April 18, 2012, 03:06:52 AM »
I think you missed forum, this is not about industrial design :-))))))))) ... I must thing how to incorporate something from my virtual body to look of my future electric model :- )))))))
you had to post it to that photo contest thread instead of that red baron, you could win something  LL~ :- )))))))))))))
btw this is not pitch gauge, this is automatic pitch gauger :-))))))))) ... you should teach him how to make perfect prop  VD~
Offline Tom Niebuhr
« Reply #25 on: April 18, 2012, 09:42:22 PM »
Igor.. Great idea!
Tania,
He would make a great pilot for Derek's Matrix.
AMA 7544
