  • April 18, 2024, 06:43:45 AM
Author Topic: 5 Oz. Syringe  (Read 11602 times)
Offline Joshua Harel
5 Oz. Syringe
« on: January 23, 2012, 05:34:36 PM »
Hi Jim
I am interested in buying your syringe. Where can I find info. about it as well as price? Also, will it work with Diesel fuel?
Joshua
Offline James Lee
Re: 5 Oz. Syringe
« Reply #1 on: January 25, 2012, 08:02:29 PM »
Joshua
I have the 5 oz syringe in stock at $24 plus $3 shipping...
Send me an email at   jlee9 at cox.net for a full product list
Jim
Offline BillLee
Re: 5 Oz. Syringe
« Reply #2 on: January 26, 2012, 04:19:54 AM »
Jim, what material do you use for the o-rings in the syringe?
Bill Lee
AMA 20018
Offline James Lee
Re: 5 Oz. Syringe
« Reply #3 on: January 26, 2012, 03:29:33 PM »
The syringe normally is fitted with a Buna - N rubber o -ring.  OK for glo, gas or diesel....    I have a silicone oring available for $1.00, but it does not like diesel or gas.  Also a viton oring for $2 that is supposed to be impervious to most everything....    for most people the regular oring is quite adequate, giving very good service....
Jim
Re: 5 Oz. Syringe
« Reply #4 on: February 22, 2013, 12:53:34 PM »
Jim.  I'm looking for a fuel syringe for gasoline.  Are yours glass or plastic?
Floyd Carter
Offline James Lee
Re: 5 Oz. Syringe
« Reply #5 on: February 23, 2013, 10:55:41 AM »
The syringe is plastic of some type....   The standard one I sell is good for gas if you use fuel line that will tolerate gasoline....
Jim
Offline James Lee
Re: 5 Oz. Syringe
« Reply #6 on: May 19, 2013, 10:54:17 AM »
MotorMan
One problem I've seen several times is that the delrin piece that holds the oring expands with nitro...   You might check and see that this piece is not binding in the syringe body.  Remove the oring and see if it is free in the syringe bore.   That is an easy fix with a slightly smaller diameter oring carrier piece.
If the syinge is not used for a period of time, typically it will lose suction about halfway up the syringe.   Leave some fuel in the syringe for a few minutes and it will normally then work fine.  The orings apparantly do expand with exposure to fuel and then shrink when not exposed for a some time ( a week or more ..).
I think the barrel may shrink, but I have rarely seen that...
Possibly a viton oring may be the solution.
Also, a big factor could be the fuel itself...   High nitro or a different oil....
Jim
Offline WR Crane aka MrClean
Re: 5 Oz. Syringe
« Reply #7 on: January 08, 2016, 06:20:07 PM »
What is the warranty on your syringe.  Mine is a little iffy at sucking fuel.  I'll give the soak it in fuel trick a try a couple days before I use it next.
Oh, and I don't have the receipt as I bought it ohhhhh, bout when did you start making these?
I also need to talk to you about 4 strokes.  Just wanted to know if the design is the same as in the beginning and if maybe I should try a new oring after 10? years?
Offline James Lee
Re: 5 Oz. Syringe
« Reply #8 on: January 09, 2016, 09:57:15 AM »
Mr Clean aka WR....
Great to hear from you again!
My prototype syringe says 2004....   Yes, after 10 ( or so...) years the o-ring might have degraded performance...
Let me know what you need...
Jim
Re: 5 Oz. Syringe
« Reply #9 on: January 10, 2016, 07:53:27 AM »
Next time I know I'll be in town I'll give you a heads up.  Might be a couple months.  I know better then to bother around contest days.  Will either get this one sucking again or buy new.  Not enough time to fly and be competitive but I get times when I can work some angst out in the front yard.
