  • April 19, 2024, 01:08:29 PM
Author Topic: Venturi Inserts  (Read 3761 times)
Offline Dennis Leonhardi
    • AirClassix on eBay
Venturi Inserts
« on: January 11, 2012, 06:55:14 PM »
Jim, I could use an insert or two for the Magnum and Thunder Tiger .10 engines.  Thunder Tiger supplied a "sprinkler type" venturi which is perfect for these engines, but they're virtually impossible to find.  For that matter, the "sprinkler" type probably isn't necessary, just something that works!
If I send you a Thunder Tiger venturi, can you duplicate it or make something comparable?
For that matter, do you have on hand or readily available venturis for some of the "standard" engines, such as the OS Max FP series?  If so, I'd like to see a list of what you can supply, with prices.
Thanks!
Dennis
Offline James Lee
Re: Venturi Inserts
« Reply #1 on: January 25, 2012, 07:59:52 PM »
Dennis
Sorry for the delay...   Hadn't been on the forum in a while...
I can probably duplicate the venturi...   I would rather work from the actual motor and venturi to see exactly how it fits...   I know it is more expensive to send the motor back and forth, but I would rather that than have a piece that doesn't fit...
And if you send me an email at jlee9 at cox.net   I will send you my product list.  And I carry a full line of delrin venturi's for the FP/LA motors.
Jim
Re: Venturi Inserts
« Reply #2 on: September 24, 2012, 10:28:14 AM »
Do you have or can you make a venturi setup for the Evolution .46 in the same style as the Evo 36? I believe it is the same size as the EVO 60.
