  • April 24, 2024, 12:15:08 AM
Author Topic: Compatibility and Interchangeability  (Read 3609 times)
Offline Clancy Arnold
« on: December 27, 2011, 07:25:42 PM »
I was asked if the U/Tronics Control Multi channel systems were matched sets?
The answer is NO!
The question was did the modeler have to keep a Handle with Encoder to use only with the Decoder it came with.  He did not want to have to remove the Decoder from one model to use the Handle on a second model or could he use a different Decoder with his present handle?
The design of the Encoder and Decoder make them universally compatible.  In fact you could use a 7 channel Encoder to control a 4 channel Decoder with the limitation of only having 4 useable channels.  you could also use a 4 channel Encoder to control a 7 channel Decoder again with the limitation of only having 4 useable channels.
I think that makes them Compatible and Interchangeable.
Clancy
« Last Edit: December 27, 2011, 07:55:53 PM by Clancy Arnold »
Clancy Arnold
U/Tronics Control
