  • June 20, 2025, 07:18:33 AM
Author Topic: Nemesis II plans (authorized by H. Rush)  (Read 7969 times)
Offline Gary James
  • Shredding streamers since 1971
    • Mini-IMP Aircraft Co.
« on: December 23, 2011, 07:47:58 PM »
Attached is a set of CAD Nemesis II plans re-drawn from the AAM magazine article.  Authorized by Howard Rush.  Also attached is a re-typed copy of the text from the magazine.  Enjoy.
Gary James
Weatherford, TX
AMA 68845
Re: Nemesis II plans (authorized by H. Rush)
« Reply #1 on: December 24, 2011, 08:55:25 AM »
Gary, thanks for the plans and article.   Still have my plans I bought off Howard the year he won the NATS.   He was on that year.    H^^
« Reply #2 on: December 24, 2011, 03:27:19 PM »
Thanks Gary.   H^^   lost the plans long ago,  its still one of my favorites.
« Last Edit: December 25, 2011, 02:20:37 AM by Joe Yau »
Offline Rafael Gonzalez
« Reply #3 on: February 10, 2012, 01:48:47 AM »
WOW!! Thank you! I now know what I will be building for this season... I have a few MKIV's hanging around in a plastic bag...
 H^^
« Reply #4 on: May 01, 2012, 09:32:28 PM »
Howard  Gary
Thanks much for the work on the plans and making them available,
Howard do you have any opinion on a foam Nemesis? ever see or fly one? I was curious given the other combat ships that work really well in foam
« Reply #5 on: May 02, 2012, 12:24:47 AM »
I never thought of that.  Foam kinda invited tapered wings and longer span.
« Reply #6 on: May 06, 2012, 08:34:30 PM »
Having built a foam wing or two, a foam Nemesis would probably either be too heavy(solid foam) or too weak(hollowed panels.  The wing barely has room for the bellcrank, so construction would be difficult.  The bladder tube hole would be difficult to cut.   It might be a bit faster to build since you don't have as many parts to cut and fit.
Give it a try and let us know.
Offline Gary James
« Reply #7 on: May 24, 2012, 07:52:03 PM »
Howard  Gary
Well, my flying partner and I sorta-kinda developed and campaigned a "foam Nemesis" which we first flew at the 1972 NATS.  But like Howard said, foam lent itself to longer spans and tapered wings.  We used the basic Nemesis center-section construction and airfoils and added tapered outer panels to bring the span up to 42".  The airplane was fairly well received on the west coast and one of the juniors (Joe Kall) won the junior NATS with it in 1975. Of course Joe is probably about 50 years old now. We really didn't promote the design, and it was never published, but it was called the Shrika II. The 1.0 version was not structurally sound as we had not figured out how to hold an engine on to a foam wing at that point.
Gary James
Weatherford, TX
AMA 68845
Offline Jim Oliver
« Reply #8 on: September 28, 2012, 06:38:22 AM »
Is there any reason not to build from a kit, if you have one?  Are the kits considered to be too ________(fill in the blank) to build?
Jim
Jim Oliver
AMA 18475
Offline MarcusCordeiro
« Reply #9 on: October 16, 2012, 04:38:48 PM »
I'm gonna get myself one of those VD~
Marcus
Live to fly, fly to live
Aces High!
Here comes Marcus, man..."
« Reply #10 on: October 16, 2012, 08:28:49 PM »
Fast Richard's kits were pretty good.  Top Flite cut the ribs very accurately.  I'd bet Phil Cartier's kits are good, too.  I had one of Phil's kits, but I don't think I looked inside.  I gave it to Derek Moran for making me some lovely control horns.
Offline Mike Greb
« Reply #11 on: August 07, 2020, 03:01:33 PM »
Model made off the nemesis II finial .pdf
Offline Terrence Durrill
« Reply #12 on: August 07, 2020, 04:06:26 PM »
Jim
       I built my three Nemesis II's from the AAM Magazine plans.....used mostly Super Tigre plain bearing combat engines.  Still have one Nemesis II kit in the shop......I never built one from a kit but you do have full sized plans and the wood looks very good.  The planes built from AAM PLANS flew excellent.  Build one and have fun........but make sure that the motor mount is super strong.  I had a Tigre G-21 .35 take off and go on its own from the first Nemesis that I built.     D>K     H^^
Offline Mike Greb
« Reply #13 on: August 07, 2020, 08:09:45 PM »
The biggest change I made from the plans was to machine the motor mount  out of a sheet of maple.  The motor mount should be able to be recycled when the rest of the model dies.
« Reply #14 on: August 07, 2020, 09:23:42 PM »
I always fibre glassed the engine pod to the wing center section on my combat planes when I could fly combat. D>K
