I am using 100% polyester dress lining. I bought it from 2 different stores and there are differences to watch out for.
First of all I did finish covering the plane I am working on and after some struggles I am very pleased. My airplane sounds like a drum now that the Nitrate Dope is dry. The skin is TIGHT TIGHT TIGHT. But only after NITRATE DOPE.
I bought some (60" wide) for 4$ a running yard at Hancock's, and also got some from Joann's (45" wide) 6$ a running yard.
The fabric from Joann's ended up having noticeably more shrink available. It is a little coarser and stiffer feeling than what I got at Hancock's.
I used MINWAX water based Polycrylic to glue the fabric down. I just brushed it onto the edges, let it dry good, then used my Monocote iron to iron down the fabric. Worked great.
Now the differences.
Turned out to be absolutely critical when covering my control surfaces. They were only 2" wide and I just could not get the rumbled bed look out of them when using the Hancock's fabric. I iron down the edges, pulling as tight as I could, then hit with my heat gun. It would shrink nice and then with in minutes relax and look like heck. So I tried the iron, a low temp, same result. Then started bringing the heat up. I went from bad to worse. So I stripped the control surfaces. I then got Some fabric from Joann's and recovered the control surfaces.It went on reasonably tight.
I covered the wing with fabric from Hancock's and I covered the fuse with some fabric I got from Joann's. I had bought different amounts at different times from the 2 stores. Both shrank OK with the air gun. . The fuse has some open areas and was noticeably tighter than the wings. But both were OK.
It is the small areas (narrow) that I just could not cover tightly with the Hancock's fabric.
To restate the Joann's felt coarse and stiffer but worked good on all parts of the plane.
I do have a build thread an a different site and I did detail covering with 100% polyester dress lining. I will use it again It was cheap and locally available. But man was it a learning curve. But then again it was my first time with the material.
Yes I know my build thread is for a RC not control line, but it makes no deference in covering an airplane what the control is. I hope it helps some one. I sure wish I had known what I have (I hope) tried to pass on here.
My build thread
http://www.rcuniverse.com/forum/m_10675544/mpage_1/key_/tm.htmThe part of the thread that is about covering is on page 2 post #47
Problem starts on page 3 post #59
A second thread I stated, asking for help, is
http://www.rcuniverse.com/forum/m_10751511/anchors_10751511/mpage_1/key_/anchor/tm.htm#10751511I cold not figure out how to link to individual post, so I hope page and post#'s were not to much trouble.
