  • June 13, 2025, 09:48:22 PM
Author Topic: MG10. new electric stunt  (Read 3120 times)
Offline Jose Luis Oterino
« on: April 03, 2011, 11:20:01 AM »
Hi All.
This is my new electric model.
Wing span: 1520 mm
Length: 1211 mm
Engine : AXI 2826/12
Battery. Turnigy nano tech 4s 3300mAh.
Timer: Jpam V.2.01 ;D
Weight: 1750 gr
Wing surface : 35,70 dm2
Flaps surface: 8,55 dm2
Tail palne surface: 7,22 dm2
Elevator surface: 5,9 dm2
Offline Bob Hudak
Re: MG10. new electric stunt
« Reply #1 on: April 03, 2011, 02:03:37 PM »
Nice job Jose. What size prop are you using?
350838
« Reply #2 on: April 03, 2011, 02:16:25 PM »
APC 13x6,5 Pusher
« Reply #3 on: April 03, 2011, 04:44:40 PM »
very nice!!!!  I like your invisable landing gear - seems to work   LL~ LL~ LL~
Online Crist Rigotti
« Reply #4 on: April 03, 2011, 04:56:49 PM »
Very nice.
« Reply #5 on: April 04, 2011, 04:53:52 AM »
Jose
VERY good job - looks wonderful.  Have you flown it yet?
« Reply #6 on: April 04, 2011, 08:21:37 AM »
Yes.. only 10 times. I am trimming...but... will be very good #^ #^
Offline JohnPrator
« Reply #7 on: April 05, 2011, 05:56:19 AM »
Beautiful plane! Do you have any photos of the electronic/motor install that you could post?
A Veteran - whether active duty, retired, national guard or reserve - is someone who, at one point in their life, signed a blank check made payable to "The United States of America", for an amount of "up to and including my life." That is Honor, and there are way too many people in this country who no longer understand it. -- Author Unknown
« Reply #8 on: April 05, 2011, 02:22:00 PM »
Offline Mike Scholtes
« Reply #9 on: April 05, 2011, 08:21:47 PM »
Hi Jose:
Can you comment on your battery hold-down system? Looks very simple and quick to operate. Have you any more photos of that part of the model?
Very pretty plane,  unusual color combination and decoration.
« Reply #10 on: April 05, 2011, 09:11:58 PM »
Hi Jose:
I wouldn't recommend using a metal or aluminium hold down on a battery pack - although it works - if you happen to have an unexpected impact with the ground - you are sure to short that pack out and get some nice "venting in flames"
Use ply or similar as a hold down - looks like the system would work either way - just not a fan of metal near LiPos'
see Bob Hunts hold down method - or the one i did on my last vector  - really easy to use and very little weight -
here....
http://stunthanger.com/smf/index.php?topic=20144.0
« Reply #11 on: April 05, 2011, 10:34:57 PM »
The item looks like plastic to me; strong, safe and non conductive. Maybe Jose will let us in on the details. I use a lite ply sliding door to hold my battery in place. I was inspired by Bob's hold down system, anything but velcro! (Er, "hook and loop fasteners.")
Offline WhittleN
« Reply #12 on: April 06, 2011, 06:27:31 AM »
Guys/Jose
That looks like circuit board material and it looks like a very simple and elegant way to hold-down a battery.  I suspect it has a bit of Velcro on the bottom of the battery.  I think I will steal this idea for my next airplane.  Good job on the entire airplane Jose.  I too will have an invisible landing gear on my next one as I just can’t bring myself to paint the nice carbon fiber landing gear and wheel pants.
Norm Whittle
Offline JohnPrator
« Reply #13 on: April 06, 2011, 04:08:39 PM »
More photos,  in my Picassa album:
https://picasaweb.google.com/joseluisoterino/MG10?authkey=Gv1sRgCLP4mpLf1aumRg#
Aaaaadios
Thank you, nice photos and such a cool looking plane-great job!
Must be going right over my head but what are these "invisible landing gear" you guys keep joking about??   ???
« Reply #14 on: April 06, 2011, 04:34:38 PM »
in all the pictures in this post - you cannot see the landing gear - but the plane is off the ground - only explantion is that he made them invisible......maybe with ACME invisible paint.......
speaking of paint - that purple is a nice colour......I LIKE IT !!!
Offline John Cralley
« Reply #15 on: April 06, 2011, 07:58:29 PM »
Wynn,
You need to crank up the resolution on your monitor or maybe consider a trade up. I can see the landing gear just fine on my monitor -- well OK maybe not in ALL the photos.  #^
John Cralley
AMA 52183
Central Illinois
« Reply #16 on: April 06, 2011, 08:28:53 PM »
Wynn,
yeah - just cranked the brightness up to a level just below "sun glare" and I can see it now......
Offline Larry Wong
« Reply #17 on: April 06, 2011, 08:52:26 PM »
Looks GREAT to me, Nice plane  #^ #^
Larry
« Reply #18 on: April 07, 2011, 05:02:47 AM »
Thank you everyone for the nice comments.
The batteries atachemnt system is based on the one used to attach the body to the rest of the car in RC car models...exactly, the mounting plate is made in circuit board material, and the plate size battery contact is protected whit  adhesive foam.
I will follow your advice and change the metal part for a plastic one.
I would never paint a cf landind gear!!! That is sacrilegeous!!!  n1 n1
« Reply #19 on: April 07, 2011, 03:53:52 PM »
Hi All
I wrote in my blog, an article on this model:
http://adarvueltas.blogspot.com/
Regards.
www.jpaeromodels.com
Timer JPamV2.01
