Howdy folks!
This is, or was, a Sig Akromaster. (Sorry Mike G.) I think that over the years Sig's nifty little Akromaster has been built in many different variations. I had two stock ones way back when I was in Junior High, and I remember having a ton of fun with them.
I actually started this particular build at least five or six years ago, and for some reason I hung it on the wall and it's been there ever since. I think we all have one of
those models.
Back then, I had this silly idea that I could "bash" the Akromaster into a Cessna Agwagon. Heck yeah, it would be super easy, just "fudge" the fuse and tail outlines a little bit and you'd have an Agwagon. Well, after "fudging" here and there, I've ended up with what you see here.
At this point the only "Sig" left in it is the ribs and the L/E and T/E stock pieces. All the rest ended up in the scrap pile. If you've ever built an Akromaster per the kit instructions you may remember that they have you cut the provided L/E and T/E pieces to length. I didn't do that. I actually lengthened them, and made some more ribs. Oh yeah, then I took them all down 1/16" around the perimiter so that I could add L/E sheeting and capstrips. I built the wing in halves and then added dihedral to the wing when the halves were joined for a more scale look. The real Agwagons have so much dihedral that a model of one just wouldn't look right without it. It actually worked out quite well because the leadouts are now very near the thrust line, maybe even right on it if I remember correctly. Then I carved out the funky-droopy-wingtip-thingies for some more scale detail. The fuse, all tail surfaces, larger area fixed flaps, longer motor mounts and nose tripler, spruce wing struts, are all new and designed from scratch. I whittled out the aluminum landing gear too.
Overall wingspan is now 41", stab/elevator span is 15", tail moment is 8-1/2" and nose moment is 4-3/4". Power will be a Fox .25. I think I might finally git'er down and finish it by this next spring, we'll see.
