Welcome, Guest. Please login or register. May 24, 2013, 08:45:37 PM
Pages: [1]   Go Down
  Print
Author Topic: Carbon Fiber Props  (Read 13490 times)
Steve Wilk
Moderator
Trade Count: (0)
Lieutenant
Rate User 0
Offline Offline
« on: December 09, 2009, 03:59:39 PM »
Cabon Fiber Stunt Props
I've been making Carbon Fiber Props for more then 15 years now with over 100 different props. I have several Stunt Props, landing gear and a 4" bellcrank and I'm in the process of adding 16 new props.  Check out the attachment to see what I have and what I'm working on.
Steve Wilk
swilk117@yahoo.com
* Stunt Prop Flyer.pdf (14.52 KB - downloaded 931 times.)
* New Stunt Props.pdf (15.39 KB - downloaded 875 times.)
* Prop List.pdf (22.23 KB - downloaded 872 times.)
« Last Edit: December 15, 2009, 07:26:35 PM by Steve Wilk » Logged
Steve Helmick
AMA Member and supporter
Trade Count: (0)
Admiral
Rate User 37
Offline Offline
« Reply #1 on: December 19, 2009, 05:17:41 PM »
Steve...I bought some of your props from Burt Brokow when he was up here for the NW CL Regionals last Spring. I haven't had the chance to try them all, but did fly the 10 x 3.5 3 blade Tornado copy. I guess this would have been a finished prop, because the balance was almost perfect and it was pretty much plug n' play. I need to increase the pitch in it a bit, but you're props are nice stuff and prices are good. I hope to get some of the others tested by next Regionals, and I'll report my findings. I hope Burt brings more props (and CF LG's) next year. I didn't get to see a BC. It would be cool if you could post some information on the codes...like the T3-1 is the 3 blade I tried, and what's this T-11 for? Etc.!   Hoff Steve
Youse guys buy props from Steve Wilk!
« Last Edit: June 19, 2011, 10:31:47 PM by Steve Helmick » Logged
I once killed a twelve pack just to watch it die.
Which is worse? Ignorance or Apathy? I don't know and I don't care.
This retirement gig is great. Like being on welfare without the stigma, drugs and munchies.
Steve Wilk
Moderator
Trade Count: (0)
Lieutenant
Rate User 0
Offline Offline
« Reply #2 on: December 19, 2009, 07:32:12 PM »
Hi Steve
Thanks for trying my props.  I currently working on a web page that will have all the info on each props along the prop orgines. I'm also make molds for several of the Rev-up props and hope to have those available next month.  I've attached a Pic of the Bellcrank.  The Bellcrank is made from one piece 12K tow, wrape around several times.  It has a 1/8" ID bronze pivot bushing with 3/32" ID brass lead out bushings.  The hole for the pushrod are left out so you can place them where you need them.  Dubro 1/16" ball links work best for a pushrod connector.
Thanks Steve
T-11             9   X 3 1/2     Grish/Tornado
B-7        9 1/2   X 4          Bolley
S-4      10 5/8   X 4 1/4     Modusa
S-6            11   X 5 1/4     Modusa
S-7      11 3/8   X 5 1/4     Modusa
S-8      11 3/4   X 6          Modusa
S-9            13   X 5 1/4     Modusa
S-10            13   X 6          Modusa
T3-1            10   X 3 1/2    Grish/Tornado
Logged
Gerald Schamp
AMA Member
Trade Count: (0)
Lieutenant
Rate User 1
Offline Offline
« Reply #3 on: February 26, 2010, 12:13:02 PM »
Hi Steve,
I am looking for some carbon fiber landing gear for profile models. I understand that you make or have these. Would you email me at: geraldschamp@comcast.net and let me know. Walter Hicks told me about these.
Gerald Schamp
Logged
Steve Wilk
Moderator
Trade Count: (0)
Lieutenant
Rate User 0
Offline Offline
« Reply #4 on: February 26, 2010, 04:29:47 PM »
Hi Gerald
I do have have landing gear for a Profile Stunter P-40 class.  I've attached a coulpe of pics
                                                           unfinished    finished
CF Profile Stunt LG                           $25.00   $30.00
CF Profile Stunt LG w/CF Cloth           $30.00   $35.00
swilk117@yahoo.com
* LG Drawing.doc (21 KB - downloaded 180 times.)
Logged
KEITH McCRARY
Trade Count: (0)
Ensign
Rate User 0
Offline Offline
« Reply #5 on: March 15, 2010, 06:09:24 PM »
Steve, what is the total weight of a complete pair (right and left) of the large carbon fiber profile landing gears.
Keith McCrary
Logged
Steve Wilk
Moderator
Trade Count: (0)
Lieutenant
Rate User 0
Offline Offline
« Reply #6 on: March 15, 2010, 06:16:12 PM »
Hi Keith
The weight of a pair of carbon fiber landing gear is 60 grams or 2 1/8 onces
The weight of my 4" bellcrank is 7 grams or 1/4 once
Logged
Dwayne Donnelly
Trade Count: (0)
Captain
Rate User 17
Offline Offline
WWW
« Reply #7 on: October 07, 2010, 08:03:01 PM »
I'd really like a 11X5 3 blade.
Dwayne
Logged
maac 44334
Pages: [1]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines
Valid XHTML 1.0! Valid CSS! Dilber MC Theme by HarzeM
