The motor is a speed 400. Take the one with the highest voltage I believe 7,2 Volt.
I used 3 batteries in serie 28,8 Volt
Prop is a gunter prop. You have to drill it a little and glue it. otherwise the prop will fly of or breake at the hub.
The line length is about 9 meters I think.
The big trick is to use a bigger diameter at the handle and a thinner at the plane.
If you calculate were the power drop is it will be in the thinner cable. in this way you can use longer lines.
At the beginning they were to long.
I made a PWM regulation to regulate the power.
It was perfect for the kids also because the can adjust the speed.
Greetings Robert-Jan
